      01-18-2019, 09:42 PM   #221
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Originally Posted by zx10guy View Post
Are you still dealing with Frankie?
You bet!
      01-18-2019, 09:45 PM   #222
P1
P1's Avatar
11572
Originally Posted by djsaad1 View Post
Do they still have the smart features like line crossing detection, scene change, etc...? I use blue iris for motion either way, but just curious.
The camera has built-in motion detection, face detection, intrusion detection and line crossing detection.
That being said, my NVR software does all that for me so I currently don't take advantage of in-camera intelligence.
      01-19-2019, 11:32 AM   #223
dsad1
Drives: car
Originally Posted by P1et View Post
This particular location had a 3MP previously. The quality difference is very, very noticeable compared to this 6MP.
I’ll post some 3MP vs 6MP screenshots tomorrow.
I went back through all the cameras to check how I set them up. I see now that only two of the outdoor cameras are 1080p, the ones that are not as important. The rest were left at 3MP.
There are 18 cameras that are recording 24/7 with 6 month retention, I try to save as much disk space as I can.
      01-19-2019, 01:07 PM   #224
P1
P1's Avatar
11572
That makes sense. When running that many cameras, and having a six-month retention policy, then recording in 6MP would require quite a bit of disk space...
      01-19-2019, 01:28 PM   #225
dsad1
Drives: car
The retention is most likely overkill. That being said, I walked out this morning and someone at the neighbors house was being arrested... We just moved in a few months ago, haven't met those neighbors yet.
P111572.00
      01-19-2019, 03:18 PM   #226
P1
P1's Avatar
11572
Time for a 4K PTZ!
      01-19-2019, 07:17 PM   #227
dsad1
Drives: car
Time for a 4K PTZ!
I do wish that I went with ptz on a couple of them. They are placed near the roof and I get freaked out messing with them while on that tall of a ladder. I have one that should be turned more to the right but have been procrastinating to go up there and reposition it.
      01-19-2019, 07:23 PM   #228
P1
P1's Avatar
11572
Trust me. I installed the easy ones. But the ones that required serious ladders, I had my AV guys do those.
      01-19-2019, 08:50 PM   #229
dsad1
Drives: car
They physically nstalled them, but I didn't want them touching the network and software, so I had to get up there to reposition them.
      01-20-2019, 08:44 AM   #230
dsad1
Drives: car
Any recommendations for wireless indoor cameras? The hikvision cubes are starting to get flaky, they have also been dropped a few times.
Is foscam or equivalent still that bad?
      01-20-2019, 08:25 PM   #231
P1
P1's Avatar
11572
I was going to say the Hikvision cubes, but it sounds like those aren't working for you. Any reason why you can't wire them and power them via PoE since you need a power cable in any regard?
      07-30-2019, 09:18 AM   #232
P1
P1's Avatar
11572
zx10guy I am looking for some direct burial terminated cat6 cabling. Anything you can recommend?
      07-30-2019, 10:51 AM   #233
zx10guy
Drives: 2013 135i
I don't have anything in mind off hand. Having a conduit and running the cabling inside isn't an option?
Originally Posted by Lups View Post
We might not be in an agreement on Trump, but I'll be the first penis chaser here to say I'll rather take it up in the ass than to argue with you on this.
      07-30-2019, 11:11 AM   #234
P1
P1's Avatar
11572
I have a spare drop by my deck, and want to extend it to my patio. I think I'll probably need 150 or so feet of cat6 to make the run. I was hoping I can just throw down some direct burial instead of having to get out the conduit and start digging.
      07-30-2019, 11:24 AM   #235
zx10guy
Drives: 2013 135i
Would something such as this work? It's a bit pricey but you're pretty much guaranteed there wouldn't be any problems.
https://www.amazon.com/Armored-Outdo...E0H676BEGW6VNW
      07-30-2019, 11:30 AM   #236
P1
P1's Avatar
11572
I actually was looking at this one...
https://www.amazon.com/Ethernet-Shin...-2-spons&psc=1
      07-30-2019, 12:55 PM   #237
zx10guy
Drives: 2013 135i
I linked the one I did because I felt having an armoured outer jacket would be something good to have to prevent accidental splicing of the cable if digging was done around it. And also to prevent critters from chewing on the cable where it's exposed.
P111572.00
      08-14-2019, 06:45 AM   #238
Yapakanichi
Monkey Marshall
Yapakanichi's Avatar
635
Drives: 2005 Z4 3.0i
Home Security Camera Systems
So I've been having some trouble with people driving on my yard and was looking at some of the home security camera systems. I can't get a good read on whether this brand or that brand is good.
So I figured one of you guys might have some insight into this.
I want something that I can monitor the front and sides of the house for now. I think x4 90degree POV cameras will do.
MDX, POE, IP, wireless, wired....my head is spinning.
      08-14-2019, 07:03 AM   #239
King Rudi
King Rudi's Avatar
13154
Drives: Meat Suit
A friend of mine and I install home security camera systems as a side gig. We basically install whatever the customer wants, but we do more POE than anything. We tell our customers to get their camera system from amazon or Sam's club and we do everything else. We have installed a lot of these systems.
https://www.amazon.com/Swann-Camera-...gateway&sr=8-3
Easy install and we have yet to have any technical issues. You can get a cheaper version without 2-way audio. There is also an app to where you can watch a live feed on your smart phone or tablet as long as you have a data connection.
Not that I need to tell you, but just a suggestion; carefully plan what you intend to capture when considering location/POV of the cameras. If your intent is to capture the license plates, you may never get a solid capture of numbers/letters based off a moving vehicle, depends on the speed they are traveling. Shop around, find a system that meets your budget, with the number of cameras that you need, and if you have any questions (on the system or installation), pm me.
Wolf 3352340.50
      08-14-2019, 08:51 AM   #240
m630
m630's Avatar
967
Drives: '22 X4M Comp / ‘22 X3 / f136
‘22 X4MC  [0.00]
I had a Lorex POE system installed earlier this year and it works great with a great app. 8.5mp cams in 4K UHD are crystal clear. They have great night capabilities too in full color as long as thete is ambient lighting available. Good luck
      08-14-2019, 10:07 AM   #241
UncleWede
Long Time Admirer, First Time Owner
UncleWede's Avatar
Drives: G01 X3 M40i Dark Graphite
Sub'd
I have an existing 2-camera system that has pretty good placement in terms of coverage, but the clarity isn't there. Since I already invested to have someone pull wiring, I'm pretty much stuck with the BNC/power options, although I've recently seen that there are still a ton of those with greatly improved camera optics. Just haven't pulled the trigger on replacement cameras/DVR. I don't need audio.
The existing system, I KNOW that fauqer when I see him walk up his driveway across the street, after parking another vehicle he is repairing on the street. But no plates. I can't even legitimately read the door panel on the tow truck that drops the vehicle. And I've seen there are newer systems where I could block the trees moving in the wind from activating recording.
I'm not interested in monitoring from my phone, just when I get home.
Recently had perfect video evidence of this yahoo who was working across the street. Went to park, backed up and pulled my mailbox down the side of the truck. He got out, looked at it, and the mailbox stayed on the post so he just went about his business. The mailbox was only held in place by a few threads and gravity when I got home. Submitted the video to the water company (who hired him to do repairs) and they paid for the materials I used to replace the post.
      08-14-2019, 10:21 AM   #242
corn18
corn18's Avatar
1712
Drives: 2020 X3 M40i
2014 Jeep Wrangler 2D  [0.00]
2015 Chevy 2500HD  [0.00]
2015 Z4  [0.00]
2020 X3 M40i  [0.00]
Nest cams for us (4x outdoor, 4x indoor). + nest doorbell and nest locks. All play nicely together and incredibly easy to install and setup.
