06-01-2008, 10:57 PM | #45 | |
Track Addict
Rep 207
Drives: E86 Z4 ///M COUPE
06-02-2008, 08:03 AM | #46 |
My favorite sign.
169
Rep 4,333
06-02-2008, 11:42 AM | #47 | |
1821
Rep 5,337
Case in point, if you just compare what is different between the E46 coupe and convertible, convertible rear seats are locked down and not fold-able (more structural rigidity), convertible rear subframe has an additional cross brace, convertible front subframe uses a heavier and stronger steel cross brace compared to the aluminum subframe brace used in the coupes, convertible A pillar design is completely different with significantly more mass added, and the E46 convertible is where BMW started to weld a cross brace from the top of the front strut towers to the chassis bulkhead. But it's pointless to continue this discussion now. I'll continue to believe what I think I know, and you'll continue to believe what you think you know. Nothing I can say at this point will convince you so I'll just go on my gouchy way. |
06-18-2008, 02:54 PM | #48 |
Rep 238
06-18-2008, 03:05 PM | #49 |
My favorite sign.
169
Rep 4,333
Prove it.
06-19-2008, 07:51 AM | #50 |
Rep 238
The car is in bending due to the vertical forces upwards from the wheels. This bending moment can be imagined as being in the middle of the body between the two wheels. In addition to the forces within the body that resist the bending moment, the coupe has additional forces down the roof pillars that resist this bending. The roadster does not have the benefit of these forces because there is no roof to support those forces. |
06-19-2008, 08:46 AM | #51 |
My favorite sign.
169
Rep 4,333
That's not exactly proof and your mechanics aren't exactly great. The only thing that could make the bending stiffness double the original would be to add supports that double the young's modulus*bending moment of inertia. The young's modulus is likely the same, so that leaves the bending moment of inertia. Now if you can prove to me that the shape of the roof pillars doubles the bending moment of inertia, i'll go along with it, but I don't see it happening.
If I get bored later I may build a simple FEA model of the car's skeleton and see what happens.
06-19-2008, 08:56 AM | #52 |
Rep 238
And the FEA model is going to show you exactly what I said. It is all about the forces down the pillars - they act as columns. The structure of the coupe is inherently more stable than that of the roadster. When you build the FEA model make sure you include these forces - if you don't you will probably just justify your own position.
06-19-2008, 09:11 AM | #53 | |
Rep 238
06-19-2008, 09:42 AM | #54 |
Rep 523
Why is it so hard to believe?
Take 4 sticks, connect them at the ends to form a rectangle, and flex it...flexes easily. Now more sticks and give the 4 sticks a roof like shape (so make a smaller rectangle and connect the corners of each rectangle to each corresponding corner). Now try to flex it. Takes more effort. Probably oversimplistic but I'm a physicist |
06-19-2008, 10:09 AM | #55 |
Rep 238
Exactly. And I was thinking of a thought experiment with a sheet of plywood, casters at the corner and a table with the legs screwed to the plywood...
06-19-2008, 12:17 PM | #56 | |
My favorite sign.
169
Rep 4,333
OMG dude. Stop saying forces. The only forces acting on the car are external. The roof supports are load bearing members...
06-19-2008, 12:18 PM | #57 | |
My favorite sign.
169
Rep 4,333
06-19-2008, 06:18 PM | #58 |
Rep 238
06-19-2008, 09:48 PM | #59 |
My favorite sign.
169
Rep 4,333
You don't understand what I'm saying. The car is acted on by external forces. The stress distribution in the car is determined by the shape and materials of the car's structure. Sure there are internal forces, but those internal forces cancel each other out in a statics problem and it's not really key to solving the problem.
In a finite element model, the most important things are to get the external loading and boundary conditions correct. Then you mesh it using a element type. The more sophisticated (higher order) element types do a good job, but when you use a fine mesh it can take forever for the computer to solve the problem. Usually what you do is use at least a quadratic (curved side) element (for 3D solids you'd use a quadtratic tetrahedral element) and refine the mesh until the solution converges. Now if I simplified the problem and made it a beam made of a certain kind of material, the shape gives it a certain moment of inertia. Adding the roof supports would change the shape, and keeping the material the same would change the moment of inertia. (Stiffness is proportional to the Young's Modulus of the material times the Bending Moment of Inertia) What I'm trying to convey to you is that I seriously doubt the roof supports DOUBLE the moment of inertia of the car's skeleton as a beam. I'm sure it'll increase but a 200% change is very large for the amount of material that is added to distribute the stresses across. So no. You can't make em out of paper. But there's more to doubling the stiffness of the car than adding the roof. If you look at the skeleton closely you'll see that the roadster and coupe's differ significantly by more than just the roof supports. If you really want to know more about what I'm talking about read a strength of materials book.
06-20-2008, 04:12 PM | #60 |
My favorite sign.
169
Rep 4,333
To appease myself and the rest of you I did a quick FEA model of the roadie skeleton today. Then I added the roof.
Roadie No Roof Roadie with Roof Supports The results show that with the roof supports the stiffness is 138% of the original...not over 200%. Sounds much more reasonable to me. So...like I said...they had to have added more than just roof supports.
06-21-2008, 12:47 AM | #61 | |
1821
Rep 5,337
06-21-2008, 08:38 AM | #62 | |
My favorite sign.
169
Rep 4,333
As far as the roof goes, it's glued bolted into place, so it's not adding as much stiffness as the parts that are welded/riveted to the frame. If you want to keep doubting me that's fine...I don't really care anymore.
06-21-2008, 11:35 PM | #63 |
Rep 238
Stiffness is the ratio of force applied to deflection. Since deflection can only occur as a result of force applied, internal forces are an integral part of stiffness. You very much missed my point about making the pillars out of paper - I was being sarcastic. And, as you said, we can't make the pillars out of paper BECAUSE THE STIFFNESS OF THE STRUCTURE WILL BE COMPROMISED. Therefore, any discussion of stiffness MUST include analyzing the internal stresses. As you have actually done in the FEA. And, as long as we are talking about the steel members of the car, we do not need to worry about changes in Young's modulus because, more than likely, it will remain constant as it only varies by a very small amount across different steels.
Very interesting FEA presented and probably not near as simplistic as you have stated. I note that you have simply divided the max stress area in the roadster by the max stress area in the coupe. However, this maximum occurs OUTSIDE the passenger compartment. The passenger compartment should be the only part of the structure that should benefit from the additional stiffness. As usual, the real answer is in the eyes of the beholder. Further investigation of the FEA shows that, in the area of the left sill, the factor is closer to 2.7. In fact, we could probably find almost any factor we were looking for, along with the accompanying error involved with correlating colors with deflection. Where did BMW measure the stiffness difference? We don't know this and all of us are only fishing in the dark. We also have already noted that the coupe weighs 33 lbs. more than the roadster. We will be hard pressed to come up with more structural material elsewhere in the coupe. If we might take a blind guess at the actual amount of steel added to the car by adding the roof and say that it is equivalent to, say, a sheet of 20 guage steel 4 ft. square. At 490lbs/cu-ft this sheet would weigh, you guessed it, 32.67 lbs. So, if they added more, where is it? I also will not take offense at your sarcastic little comment about strength of materials. And, for consistency, you really need to ensure that the forces are applied the same way in both models. |
06-22-2008, 11:09 AM | #64 |
Rep 282
Drives: '15 M235 & '95 M3 tracktoy ;
If the additional stiffness that's being seen is not due to the roof and related changes, where is it coming from? Why would BMW provide additional stiffening elements to the coupe and not the roadster?
Considering all the additional structure that is typically added to a chop-top coupe to bring its stiffness back up into the neighborhood of an original coupe structure, (and how flexible most convertibles remain,) it's not incredible to figure that a simple roof-ectomy results in a 50ish % loss in stiffness prior to reinforcement. |
06-22-2008, 05:15 PM | #65 | |
My favorite sign.
169
Rep 4,333
Next, realize that the Finite Element Method takes care of all the internal forces stresses and strains by way of the interpolation function (element type) and by using any of a variety of methods, either the direct method (force balancing) or by using the method of minimum potential energy or galerkin's method, etc. For the end user it doesn't really matter, as long as your boundary conditions and your external loading is right, it'll all work out assuming you have no issues with the mesh. This why you usually mesh the thing multiple times until your solution converges. So, unless you're trying to build an FEA model by hand or you're looking at it analytically, like I said...IT DOESN'T MATTER. The software, provided you're using it correctly, does it for you. As far as the amount of material added and extra stiffness goes, like I said it probably has more to do with a change in bending moment of inertia. Just from looking at the pictures of the skeleton you can see that the frame has box beams in the coupe and a tube or cylindrical frame in the roadie. That can make a big difference in moment of inertia without changing the mass of the frame significantly. Why do you think most buildings are made with I-beams? They have a high moment of inertia and they save weight. Any other questions? Or should I give up? Oh and sorry for the sarcasm...I tend to get that way when people argue with me and they don't really know what they're talking about. And if that offends you fine...but I'm an engineer and I know what I'm talking about it. And I get a little tired of defending my opinions from people who have a limited understand of mechanics.
06-22-2008, 05:17 PM | #66 | |
My favorite sign.
169
Rep 4,333
And as far as why BMW does anything, I dunno, ask them.
