06-15-2008, 06:42 PM | #1 |
Rep 1,191
huge maintenance done
so i replaced following... oil/filter, trans fluid, Diff fluid, Coolant, thermostat, water pump, both fan belts, vanos seal, valve cover gasket, tire rotation all in 8 hours total.
NOTE- when doing VANO/Water Pump. You might wanna get a big pry bar to push the engine back a little. there is NO way in hell they are coming out without a pry bar. the front bracket/brace is so close to the front of the engine, it does not want to come out at all. This is the hardest procedure of all. my thermostat/water pump is still like new. I might sell or keep them. @ 83,000 miles, I was so surprised how clean my engine was. no crud no build up of anykind. even Vanos seal wasn't that "loose" but car is running better than before
2022 GLE 53 Coupe
06-15-2008, 08:17 PM | #3 |
Rep 2,128
06-15-2008, 11:37 PM | #4 | |
Rep 1,191
still surprised by it
2022 GLE 53 Coupe
06-15-2008, 11:46 PM | #5 |
Rep 421
Dude, props for doing your own work. I'd have to agree thats a very clean looking top end I'm sure you've seen the threads of people doing the valve cover gaskets with huge sludge buildup.
06-15-2008, 11:48 PM | #6 |
Rep 1,191
yea I've seen some nasty sludge build ups. I am confident now, I can drive my car hard, without breaking down, for next 100k miles still
2022 GLE 53 Coupe
06-16-2008, 02:51 AM | #10 | |
Rep 615
looks good for 15k oil changes ... hopefully mine looks the same
'03 3.0i z4: tiag ext., red int., SMG, sport, premium
HAMANN exhaust l HAMANN front lip l 19" Miro type 366 (HAMANN edition race replicas) l RPI air scoop l KW v2 coilovers -*MY PICTURE THREAD*- |
06-16-2008, 12:35 PM | #11 |
Rep 1,689
Are you using RedLine D4ATF for the tranny fluid?
2010 BMW 335d "Ha! She wants the D."
2006 VW Jetta 2.5 Once upon a time... '03 VW GTI, '99 Audi A4 1.8TQ, '00 VW Jetta 1.85T, '09 BMW 335i xDrive, '04 BMW Z4 3.0i, '01 Audi TT 1.8T, '04 Volvo S80 2.5T |
06-16-2008, 02:17 PM | #12 |
Rep 1,191
thats what they have recommended on E46 fanatics but they are also using half D4 ATF(THIN) and MTL(THICK) but redline guy said we probably shouldn't be mixing the two as one is ATF and the other is Gear Oil. but who knows
D4 has worked fine for me, so I'll continue to use it.
2022 GLE 53 Coupe
06-17-2008, 10:18 AM | #13 |
Rep 1,689
So D4ATF for the tranny (which is for automatics btw), and using MTL for the rear diff?
Is 75w90 too heavy for the diff?
06-17-2008, 10:34 AM | #14 |
Rep 1,191
don't know about the auto tranny I have manual and it recommends An ATF for some reason. diff recommends 75-80 gear lube.
2022 GLE 53 Coupe
06-17-2008, 10:50 AM | #15 |
Rep 70
Drives: 2008 Z4, 2004 545i, 2004 MCS
Very Nice!!
I am impressed that you decided to tackle the job yourself I am more impressed at how clean your valve train is!
I love Alpine White BMW's
