      09-21-2019, 11:33 PM   #1
ZeD4Mr
ZeD4Mr's Avatar
Drives: MR
It's not my Z but another car.
Is the general consensus that when I use lowering spring on OE shocks, car is floatier (softer rocking back and forth more than OE at highway speed) means the the OE shocks are not strong/hard enough to properly push back quick enough when compressed?
Only apparently during highway speed after a big slow dip/bump..
Facebook -- > facebook.com/Skyermotorsport/
      09-22-2019, 12:41 PM   #2
3002 tii
3002 tii's Avatar
Drives: Z4M, X3 35i, i3 REx
If it feels harsh/jarring when you hit potholes (slower speeds) and floaty/bouncy on dips (highway) speeds then the shocks are worn. How many miles on them? If the springs are really aggressive, I'd consider replacing with a non-oem shock (e.g. Koni or Bilstein).
Follow for latest mods
      09-22-2019, 01:23 PM   #3
ZeD4Mr
ZeD4Mr's Avatar
Drives: MR
Only has 4000 miles on this brand new car. Spring lower it by about 1". slow speed are fine like OE. Only at highway speed.
spring is too hard for the OE shocks or ther other way around?
Thank you for your insight.
      10-09-2019, 08:51 AM   #4
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
951
Drives: 2007 Z4MC
as said before, if the car is moving around on the springs, the shocks are rubbish/shot/need to be replaced. dropping the ride height with stock shocks brings another issue with it aswell as those shocks are designed for stock ride height. if your changing ride height, go for a shock/spring combo that is know to work well.
2007 EuroSpec Z4///MC DIY Arial. Carma FF race exhaust. Cust. D///MK 6 Speed ultra SSK. CDV X. CSL 19" Rims. Apex 75mm kit. Stoptech brake lines. APR Aero. CSL intake. Epic Alpha-N. KW CS. SS sec1. 288/280. ECS power pulleys. Tillet B6Fxl. Sabelt.Varis. Brembo GT. ME STB. JB/Sachs Race SMFW .
      10-09-2019, 10:55 AM   #5
ZeD4Mr
ZeD4Mr's Avatar
Drives: MR
Thanks,Vanne. Unfortunately, no lowering shock/coilover is available unless go to airbags.
      10-11-2019, 01:32 AM   #6
Vanne
Down Under!!
Vanne's Avatar
951
Drives: 2007 Z4MC
I used a set of h&r lowering springs with hd Billy struts. Perfect combo and pretty darn cheap. (Z4 specific parts)
      10-11-2019, 09:04 AM   #7
Yapakanichi
Monkey Marshall
Yapakanichi's Avatar
386
Drives: 2005 Z4 3.0i
I'm sitting on Billy sports with H&R springs.
Search this Thread:
Advanced Search
Copyright ©2000 - 2020, vBulletin Solutions Inc.
