01-19-2023, 07:52 PM | #2751 |
Rep 1,543
A new windshield seal!
I'm still on the original (2007 MY/2006 build date) and it's cracked thru in a several place but isn't yet crumbling. It's had a good run for 15-ish years.
- Jeff
bosstones' flickr |
wdb4732.00 |
01-20-2023, 07:25 PM | #2752 |
Rep 198
Drives: BMW Z4C 3.0si 3 pedal
Rouge engineering Hybrid FCAB, New Performance Gearing custom ramping 1.5 way LSD 3.73 ratio, New Subframe and diff bushings, Mason Clutch Pedal w/ Bronze bushings, Fresh set of Kumho Ecsta730 255 / 265 tires for 23 season Autox.
wdb4732.00 |
02-03-2023, 05:18 PM | #2755 |
Rep 198
New rubber for the Autox season
2 New sets of rubber for the upcoming AutoX season.
Kumho Ecsta730, ran these this past year when they first came out, so far so good inexpensive tire with good grip outside tread wears to an almost soft slick compound. |
wdb4732.00 |
02-04-2023, 09:48 AM | #2756 |
Rep 399
custom made rear brake lines 27.5" long with banjo fitting
02-04-2023, 09:55 AM | #2757 |
Rep 399
Girodisc titanium shims for my Brembo BBK
grannyknot951.50 wdb4732.00 |
02-10-2023, 03:05 PM | #2760 |
Rep 198
New to the E86C, set of BBS RG-R for the coming AutoX season with reduced weight.
02-11-2023, 07:42 AM | #2762 |
Rep 399
Brembo GTS BBK - BR M O
Powered by
02-11-2023, 08:38 AM | #2764 |
Rep 399
Powered by
02-12-2023, 11:54 AM | #2766 |
dances with roads
4732
Rep 4,096
02-13-2023, 08:34 AM | #2767 | |
Rep 399
https://ebcbrakes.com/products/ebc-titanium-shims/
Powered by
02-14-2023, 10:42 AM | #2768 |
Rep 14
Just bought this half cover. The Z4 is laid up for the winter but now be spending some time in the summer outdoors with the garage housing other toys. Pics are from the EBay ad as I don’t want to take mine out of the case.
Efthreeoh17318.00 |
02-14-2023, 08:48 PM | #2769 |
Rep 198
Valve cover / seals
New valve cover and seals. Note to self: NEVER use a silicone lube on spark plugs thinking it will make the coil pack easier to remove, NOT . It makes them almost impossible to remove due to suction on plug won't break free.
02-23-2023, 08:00 AM | #2770 |
Rep 198
Skyer Carbon engine covers, Zimmerman rotors and the BBS RG-R W/ KUMHO ECSTA730 installed
03-23-2023, 08:11 PM | #2771 |
Rep 12,565
Finally installed the OEM first aid kit box. Man this thing is smaller than what I thought. I was planning on throwing the user manual in there but it’s not even close. Maybe I’ll throw in my portable jump starters…. assuming it fits
