XBimmers.com | BMW X6 Forum X5 Forum
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > General BMW X6 and X6M Forum
      12-23-2020, 12:56 PM   #1
orgullodemexico
Drives: '09 X6 '04745Li '97 Z3
X6 has power - fully charged battery - no crank
This just occurred within the past 24 hours
2009 BMW X6 - 3.5L - 90K miles
Without any warning, I insert the key and engine doesn't crank. I put the charger on overnight (battery is 2 yrs old)
I have read some discussion about Car Access Relay. However I can't verify that the X6 model has this relay, I do find discussion about a Car Access Module, under the steering column. This sounds as if it's beyond the DIY
I've also checked two fuses - labeled as Car Access in the fuse panel at the passenger footwell.
My 745Li had a burp like this several years ago. I recall disconnecting the battery for one hour, and after reconnecting everything was fine
What is everyone else's experience? I am trying to avoid a two, but I fear the worst
Happy Holidays and for those of you that haven't been stranded by your Bimmer - happy motoring
      12-24-2020, 12:34 AM   #2
BigHunk
///M
BigHunk's Avatar
Drives: X5M , iX , S1000XR
If you checked fuses under the hood, then you're probably in for a new starter.
Also check ground cable from battery to chassis.
not rich enough to buy cheap
      01-07-2021, 03:03 AM   #3
lexkaz
BMW fanatic
Drives: BMW X6
if this "click" but do not crank then you have few attempts left before starter die.
take if to shop to rebuild starter.
if it does not click then you have CAS - DME adaptations need to be reset.
      01-14-2021, 02:22 PM   #4
bimmergixxer
Railside Performance
bimmergixxer's Avatar
Drives: E92 M3 R8 V10 Q5
solution:
Connected a jumper cable from ground to the engine, and the car fired up.
After some inspection, I discovered two ground cables mounted on the passenger side inner fender that looked corroded. I wire brushed the connector plate and the cable terminals, reconnected and the engine fired. I disconnected everything to test my theory, and no start. Reconnected and the engine fired up
I'd like to know what both ground cables feed. One cable I identified on realoem.com as part # 12-42-7-574-962 "interference suppression band" What does the other cable feed?
I've read issues about the ground cable to the starter motor, but I'm without ability to lift the vehicle at this time but will pursue.
E92 M3 Manual
R8 V10 Manual / Audi Q5
Ducati Streetfighter 1098 / BMW R NineT Racer
Ducati Monster 796 / Ducati Bronco 1964
      02-12-2021, 05:11 AM   #5
Bilbofraggins
Bilbofraggins's Avatar
Drives: 2013 X6M, 2019 X3 M40I
Any braided ground strap can be used to replace corroded ones.... 5 bucks vice 30 for a BMW branded piece...
      02-12-2021, 05:13 AM   #6
Bilbofraggins
I did one on the rear drivers side chassis...it had disintegrated...
      04-23-2024, 05:32 PM   #7
Bilbofraggins
Slow crank...barely turning over....
Drivers side rear strap in place but needs a clean...
Anyone advise where else to look on the X6M for ground issues....
Replaced the battery...No current electrical issues or codes...driving great...
      04-24-2024, 01:53 PM   #8
Bilbofraggins
Ref above....exhaust and rear diff suppression cable replaced. Rear diff was completely broken. Crank situation has improved.
Still looking for the one on the tranny...
      04-28-2024, 08:02 PM   #9
corwhy
corwhy's Avatar
Drives: x6 e71
2009 BMW E71 X9  [0.00]
Check your battery in your remotes.
xbimmers
