04-04-2021, 02:42 PM | #1 |
Rep 12,565
SOLD: 18” Mint Apex EC-7 + Michelin Cup2
Sold Last edited by 3002 tii; 09-12-2023 at 11:27 PM.. |
04-07-2021, 11:02 AM | #2 |
I like Coffee & Z4s.
106
Rep 366
Drives: 2007 Z4MC
can you provide the offsets
05-04-2021, 07:34 PM | #4 |
Rep 12,565
05-04-2021, 07:35 PM | #5 |
Rep 12,565
Your inbox was full so I posted a visitor message
11-07-2021, 07:20 PM | #6 |
106
Rep 366
Drives: 2007 Z4MC
Bump for a good deal
11-12-2021, 09:43 AM | #7 |
Rep 5,328
great offset for a properly driven z4m.... these with the right settings and tyre should provide zero rub.
3002 tii2281.50 |
11-12-2021, 11:08 AM | #8 |
Rep 12,565
After driving square for so long I realized I don’t rotate as often as I thought I would, so may as well just maximize grip on both front and rear. Car still rotates fine with trail braking
11-25-2021, 11:16 PM | #9 |
Rep 5,328
OP can you snap a pic now the wheels are off and send in the common rub points front and rear please..... feel free to PM , will be interesting to see the fender liners will if much at all were touched, you drive this ca PROPERLY so if its super miner like a glacing scrape, i personally would be bothered that. Had a Gt3 RS in my shop, removed the wheels for polishing and ceramic wok and to my shock the stock wheel rubbed the liners significantly , like really bad!
11-25-2021, 11:22 PM | #10 | |
Rep 12,565
11-26-2021, 10:06 AM | #11 |
Rep 5,328
thanks very much for the reply, i think it will help people workout what they can and cant expect as this is about as a aggressive as you can go without too much work.
11-29-2021, 09:58 AM | #12 | |
Rep 12,565
Right side fender - very light rub, hard to see but that tiny triangle is the worst area. (Sorry not sure why the app uploaded it rotated) Left side is worse, result of this one particular track. Since then I raised the car tiny bit and it helped a lot. I would say right side is more indicative of what you could expect with an R-comp. On a 200TW with -3.0 camber (or at stock height), I don’t think you’d have any real issues. But to me this is more of a height issue. 245 isn’t that wide but the 40 profile makes it tall. 255/35 up front would be an easier fit imho. I ran that on my previous N52 couple with 17x9.5 et35 with 5mm spacer and that didn’t rub at all. Last edited by 3002 tii; 11-29-2021 at 11:31 AM.. |
11-29-2021, 10:18 AM | #13 |
Rep 2,866
That is a common rub area up front. Mine (although not as bad) had some slight rub even on stock wheels/tires/ride heights.
11-29-2021, 11:17 AM | #14 |
Rep 5,328
awesome info OP.... i agree 35 section tyres would more than likely solve that. Bump for some awesome wheels.
one last thing.... is any rear rubbing in the same place just at the rear most of the car.... outer fender bumper clip area , and in comparison to front , what degree?
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 11-29-2021 at 11:39 AM.. |
12-03-2021, 11:36 AM | #15 | |
Rep 1
Tire currently has Hakkas on OEM 224s. Right side fender - very light rub, hard to see but that tiny triangle is the worst area. (Sorry not sure why the app uploaded it rotated) Left side is worse, result of this one particular track. Since then I raised the car tiny bit and it helped a lot. I would say right side is more indicative of what you could expect with an R-comp. On a 200TW with -3.0 camber (or at stock height), I don’t think you’d have any real issues. But to me this is more of a height issue. 245 isn’t that wide but the 40 profile makes it tall. 255/35 up front would be an easier fit imho. I ran that on my previous N52 couple with 17x9.5 et35 with 5mm spacer and that didn’t rub at all. _________________________ Bugarsky & Navarro, LLC Last edited by robertryan; 12-03-2021 at 11:43 AM.. |
12-22-2021, 03:54 PM | #16 |
Rep 12,565
Bump
05-16-2022, 06:42 AM | #17 |
Rep 12,565
Price drop 1350 picked up in CT
05-16-2022, 01:29 PM | #18 |
106
Rep 366
Drives: 2007 Z4MC
What are the date codes on the tires?
Which one has the patch, 245 or 265? How much tread is left? |
05-16-2022, 02:40 PM | #19 |
Rep 12,565
265 has patch. I think these are 2015, been sitting wrapped in tire warmers in my basement for 2 years now. Wouldn’t hesitate driving on them for street but I know how people get sensitive on DOT codes so basically throwing them in at this price point (set of EC-7’s would still cost $1500 now with shipping).
05-16-2022, 03:53 PM | #20 |
Get off my lawn
932
Rep 1,159
Drives: 6MT
Great set of wheels. I am tempted to snag these for the street, wish you were a bit closer to the Midwest to avoid shipping.
05-21-2022, 02:30 PM | #21 |
Rep 12,565
