03-23-2023, 01:43 PM | #2 |
Rep 1,797
It looks to be similar to the E90, you'll need to remove the bumper and/or headlight to get to it unfortunately. It's located on the bottom side of your headlamp assembly (somewhat large metallic rectangular box).
03-27-2023, 06:30 PM | #3 |
Rep 12,565
Usually rectangular box mounted behind or underneath headlight housing.
Edit. See pictures in this eBay listing. It’s on the back: https://www.ebay.com/itm/13443636712...et_ver=artemis |
03-30-2023, 05:04 PM | #4 |
Rep 1
The headlamp ballast for the driver's side headlight of a 2003 BMW 530i is located behind the headlight assembly itself. You'll need to remove the headlight assembly to access the ballast, which is a small box that controls the power supply to the headlight bulb.SnapTik
