      11-17-2009, 04:30 PM   #1
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Anyone who has done any clutch changes on M
I am trying to figure out what input shaft the M transmission has.
Needs to be M specific, no SI, though it's basically the same they are not the same transmission and the input shaft is probably different.
If anyone has a picture of either the input shaft or center spline of the clutch disk that would be cool, measurements would be even cooler. Even a spline count would be nice.
      02-03-2010, 10:54 PM   #2
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
Look like they are the same for some engines.
I hope the info that I sent helped answer this question, my German is pretty basic so I also sent that to my friend in german to make sure that I got right, also forwarded the info in german to your email.
      02-04-2010, 10:30 AM   #3
F360C
Drives: E86 S54
I finally found after an hour of searching every thread I have read on bimmerfest the member with the aftermarket clutch in his Z4MR! His name is "rcleme05" and his lists an "Mason Engineering Clutch" in his sig
Edit...I actually think he might be talking about the Mason Engineering clutch pedal not clutch
07 Z4 M Coupe AW/IR
      02-04-2010, 09:52 PM   #4
silversprint
Drives: Z4M
Why not just go the BMW dealer parts department is just look at all the different stock clutch discs?
MR-S Track -2100lbs/300hp
Miata
Z4M Coupe (Sold)
      02-10-2010, 10:12 AM   #5
O-cha
O-cha's Avatar
218
Drives: Mcoupe
They don't stock mz4 clutches, only clutches that they change often. But I'm about ready to just buy one.
