11-14-2020, 11:09 AM | #1 |
I like Coffee & Z4s.
107
Rep 366
Drives: 2007 Z4MC
Z4M 245/40/R18 rubbing (18x9 ET30)
so I pulled the trigger on some tires, got em mounted, but having front fitment issues.
I thought the front would fit with just a bit of extra camber but the tires are running against the fender liner in places I did not expect, on certain turn angles. any general advice? let it rub through the liner? pics incoming. PS lowered on coilovers. ~ -1.7 camber Last edited by filtercoffee; 11-15-2020 at 12:23 PM.. |
11-14-2020, 12:37 PM | #2 |
107
Rep 366
Drives: 2007 Z4MC
driver side front where the bumper cover meets the fender:
View post on imgur.com that's where it rubs when I turn right. (well, used to rub) here's the rub point when I turn left: View post on imgur.com michelin pilot a/s 3+. probably should have stuck with 235. oh well. I hope people can learn from my mistake. and any advice is appreciated. |
11-14-2020, 03:41 PM | #3 |
107
Rep 366
Drives: 2007 Z4MC
post car wash pic
View post on imgur.com the wheel/tire diameter is larger than I projected, since there's less sidewall stretch going from 235/40 to 245/40. |
11-14-2020, 06:07 PM | #4 |
Rep 2,875
Unfortunately, that is where everyone gets tire rub when going wider. Since I'm at stock ride heights, I'm only rubbing on full compression. my solution is to just stack a few electrical tapes in that area and replace it when it rubs through the tapes
filtercoffee107.00 wdb4738.00 |
11-14-2020, 06:28 PM | #5 |
107
Rep 366
Drives: 2007 Z4MC
I'm definitely considering raising the car. it's just annoying work.
11-15-2020, 02:18 AM | #6 |
Rep 977
I would not let them rub through the liners, they are f’ing expensive. I just replaced mine at 240 each!!!!!
Get the camber washers and remove the pins. Better to wear the tire than the liner. Or change to a wheel that doesn’t rub. Liners are important to protect the lamps, horn, harnesses, etc. |
11-15-2020, 10:49 AM | #7 |
107
Rep 366
Drives: 2007 Z4MC
yikes! haha. based on where the rubbing is occurring, I'm not sure more camber will help. I give it a shot if the rubbing continues.
btw, check ebay for OEM parts next time, some dealers sell parts on there at a reasonable price. Last edited by filtercoffee; 11-15-2020 at 12:14 PM.. |
11-15-2020, 12:02 PM | #8 | |
Rep 2,875
11-16-2020, 11:03 AM | #10 |
Rep 2,705
My liners tuck inside the the fender lip where yours are shown as outside.
Is this how it came from the factory?
filtercoffee107.00 |
11-16-2020, 11:06 AM | #11 |
107
Rep 366
Drives: 2007 Z4MC
Not sure, yours is more likely to be correct since this mine has had the liners replaced at some point. Maybe that would reduce the rubbing on that side.
11-16-2020, 11:11 AM | #12 |
Rep 2,705
Could be as much as a quarter inch difference so would likely solve the rub up front.
11-16-2020, 12:29 PM | #13 | |
Rep 977
My car is my joy so was not going compromise even in items like liners, when I see a car with missing or chewed liners in my mind is an indication or carless. Damn, I have even replaced rusted hardware that no one can see. |
11-16-2020, 12:46 PM | #14 |
107
Rep 366
Drives: 2007 Z4MC
ah you're absolutely right.
update: here's a thread on the M vs non-M fender liner, in case anyone is curious to know more https://www.zpost.com/forums/showthread.php?t=1307429 Last edited by filtercoffee; 11-16-2020 at 12:54 PM.. |
11-16-2020, 02:46 PM | #15 |
Rep 264
As others mentioned, get a different tire size (245/35/18) OR increase ride height. I also had a rubbing issue when I crammed 275s up front, but after bringing the car back up to stock-ish height, rub issues went away
2017 M2 - Camber Hubs, MPE, and some other goodies 2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s 2004 Z4 3.0i - Gone, but not forgotten! |
11-16-2020, 05:17 PM | #16 | |
Rep 2,875
View post on imgur.com |
11-16-2020, 06:03 PM | #17 | |
Rep 2,705
01-02-2021, 05:51 PM | #18 |
Rep 2
I am also looking at changing out my wheels to ET30 18"x9" APEX EC-7's
I would then wrap them in Michelin PS4S 255/35-18 Lastly, I would run street camber plates in the hopes that the front tires will not rub. However, after reading this thread I am concerned. I am at stock ride height and I plan on staying there. Is your car on stock ride height? Were you able to get this issue fixed? |
01-02-2021, 07:37 PM | #19 | |
Rep 564
01-03-2021, 02:36 PM | #20 |
107
Rep 366
Drives: 2007 Z4MC
I'm lowered so I can't say for sure about stock ride height. I am living with a reduced turning radius for now.
01-03-2021, 11:59 PM | #21 | |
Rep 2
Looks like it's back to the drawing board. |
01-04-2021, 11:23 AM | #22 | |
Rep 564
Though it'd probably be harder to tell, but I've been curious how in a controlled situation these two would be, 225 or even 235 width fronts with the M caster vs 255 width fronts on non m caster. When I was deciding on power flex bush for my fcab you can pick either from power flex, but with already being my current stance I was figuring it'd be even more rubbing on the fenders than I already am so decided to stay with oe placement for the non m. I doubt it but wonder if anyone's put the non M bush to the M to reduce caster as they went wider. |
