02-12-2016, 05:29 PM | #1 |
Rep 2
Z4 Suspension. -E46??
I have a 2003 Z4
I wana know if E46 front coilover will fit Will i be able to slam it? Why? Because e46 are way cheaper Help help!!!! Yes they fit? Or no they dont!!! Please reply if you have tryed this Dont reply if you are speculating thank you!!!! HELP!!!!! HELP!!! |
02-12-2016, 06:11 PM | #2 |
Rep 2,705
I have not tried this.
I did tons of research thinking I could save a few deniros. Concluded that the parts may fit physically but the valving in the shocks and spring rates would be all wrong for the Z4 chassis. Don't cheap out on such an important safety system.
02-12-2016, 06:39 PM | #3 |
10890
Rep 4,898
Lenght of the struts may be different.
If you look at the kw v3 sets (for both e46 330i and z4 3.0i available as linear), the front linear sping on the e46 is 3cm longer.
