Go Back   ZPOST > BIMMERPOST Universal Forums > Classic BMW (Pre-2005 Models)
      09-09-2021, 07:09 PM   #1
M-technik-3
Drives: E30 M3, E36 M3, 328iT, 335i
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
E46 330xi winter beater?
It's 1500 obo and great options and looks clean in pics an engine swap is not that hard owner is non mechanical says it's leaking oil bad.
What goes bad on M54b30's? Besides coolant systems and normal BS.
      09-09-2021, 08:28 PM   #2
1SloeEm3
Drives: E92 M3
They’re Pretty solid. Front axles on the xi like to snap or the boots will rip up front.
      09-09-2021, 08:52 PM   #3
M-technik-3
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
Thanks trying to make time to inspect it sooner rather than later.
      09-16-2021, 10:52 AM   #4
Chihuahua
Chihuahua's Avatar
4075
Drives: E30 329iS, E65 Alpina B7
Oil pan gasket, valve cover gasket, the CCV valve and plastic tubing that goes with it, and oil filter housing gasket. Those are the usual suspects as far as oil leaks go, all are simple DIYs. M54B30 is a very, very solid motor. What's the mileage on that car?
      09-16-2021, 05:44 PM   #5
M-technik-3
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
115K, it's the OFH but the no start is because it's getting no fuel. suspect a bad fuel pump.
      09-17-2021, 09:48 AM   #6
Chihuahua
Chihuahua's Avatar
4075
OFH gasket is a very, very easy fix. For 1500/obo I'd scoop that one up in a heartbeat.
      09-19-2021, 11:07 AM   #7
DenverSteve
DenverSteve's Avatar
969
Drives: 2021 BMW
So you had to tow it home and you own a backpack store?
      09-19-2021, 11:28 AM   #8
M-technik-3
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
Yes Towed it home with AAA and wished I owned a bendpack store. I am a CNC set-up and operator. Good money but not fantastic money and easy work.
