01-24-2010, 03:07 PM | #1 |
Rep 14
z4 with m conversion
i have a 2004 z4 and i recently swap a m3 engine,gearbox and rear subframe with diff from a e46 into the z4..i would like to know if the z4m driveshaft would fit it?thanks
01-24-2010, 03:42 PM | #2 |
Rep 1,723
Wow thats crazy. If I were going to do that, I would have put the 4.2L V8 in there. That would be awesome.
Sorry, can't help you with the driveshaft.
BMW CCA Track Instructor
Join to win a M School Day at the Performance Center! Enter Referral ID: 420186 |
01-24-2010, 08:43 PM | #3 |
Rep 2,128
According to BMW it doesn't fit without modification, which is why the Z4M uses the transmission and driveshaft from the Z4 3.0si. According to numerous internet pundits that haven't tried it, it should fit.
01-25-2010, 11:18 AM | #4 |
Rep 815
Hmm... I knew that the Z4M rear clip (subframe/diff/suspension/axles/hubs/brakes/wheels) was a direct swap into the non-M Z4, but I didn't realize that the E46 M3 was the same. This dramatically broadens the field of donor vehicles for those of us who ever want to perform this swap.
01-27-2010, 03:38 PM | #5 |
deft danish devil
Rep 114
Drives: BSM E86 M-Cp, LMB 335d M-Sport
Very cool.. So the gearbox from the e46 m3 fit without modification? If so, that settles the "m3 transmission doesn't fit the z4, therefore BMW didn't use it in the Z4M" debate...
01-28-2010, 01:04 AM | #6 |
Rep 2,128
Err, no. BMW's claim is the driveshaft doesn't fit and none of the post above claim that it does. And it's long been known the rear of an M3 would fit, Graeme Watson in the UK swapped one onto his supercharged pre-facelift Z4 in 2004 or 2005 when no one thought there'd be an M.
01-28-2010, 08:40 AM | #7 |
deft danish devil
Rep 114
I dont understand what you are saying "err, no" to, to the only question I asked?? I said nothing about whether a driveshaft or rear end would fit..
The OP clearly states that the gearbox is in the car now,, so therefore your claim that "According to BMW it doesn't fit without modification, which is why the Z4M uses the transmission and driveshaft from the Z4 3.0si. " doesn't make sense. Why would the mis-fitment of a driveshaft prevent BMW from fitting a transmission that does fit? |
01-28-2010, 10:55 AM | #8 | |
Rep 1,723
01-28-2010, 02:51 PM | #9 |
Rep 2,128
I don't get why this is such a hard concept to grasp. From a corporate perspective, the decision on whether or not to build a low-volume model like the M Coupe/Roadster comes down to cost per unit to build. The easiest way to keep such costs down is use the existing parts bin from the outgoing M3. The added cost of modifying the M3 parts to fit is not as insignificant as everyone keeps saying -it was a matter of make the car work without any additional tooling/development, or skip making it altogether.
Yes, any Bubba with a hacksaw and a blow torch will be able to "git'er done" - but Bubba's got none of the concerns of a multinational corporate entity. Fitting it was possible, but it wasn't practical from their perspective. |
01-28-2010, 03:26 PM | #10 | |
deft danish devil
Rep 114
