11-13-2024, 09:32 AM | #1 |
Rep 15
Engine ticking
I recently got a 07 3.0i. When the weather was warmer, the engine would have a ticking sound if I left it in the garage for a few days. The ticking goes away after 8-10 minutes of driving. I did an oil change to 0-40 mobile euro syn blend and I started to notice it more. Now, even if I drove it the day before, in the cold, there is ticking in the morning for about 5 minutes or so and then it goes away. Is there a better oil to use for winter? Is there any engine work that needs to be done or could be done to help?
11-18-2024, 04:00 PM | #4 |
Rep 7,540
Your engine is specified for LL-01 A3/B4 3.5 HTHS or greater oils, so yes M1 0W-40 is a good choice. Grade is irrelevant, they are all very similar. There are not really too many thinner LL-01 oils. I would try PP Euro 5W-40 or Castrol Edge 0W-30 A3/B4 to see if they quiet it down any more than the Mobil, but the M1 is very good oil and what I would use personally.
11-22-2024, 02:48 AM | #5 |
Rep 1,035
How many miles? Service history (intervals)?
It's most likely the hydraulic lifters for the cam shafts that ticks a bit before the oil gets warm/thin enough to generate enough pressure in the lifters.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
11-22-2024, 04:18 PM | #6 |
Rep 12,732
Garage List E86 Z4 M [10.00]
F15 X5 35i [9.17] F10 550i (Retired) [9.17] F25 X3 35i (Retired) [9.43] E85 Z4 M (Retired) [9.44] E82 135is (Retired) [9.56] E90 328xi (Retired) [9.25] E86 Z4 3.0si (Retired) [8.95] |
N52 valve lifters?
11-23-2024, 03:16 AM | #7 |
Rep 1,035
Yes, how would the camshafts open the valves otherwise? They aren't pneumatically controlled.
Number 7 in this URL are the hydraulic valve lifters. http://bmwfans.info/parts-catalog/E8...amshaft_inlet/
11-23-2024, 11:57 AM | #8 | |
Rep 1,053
N52 had history with noisy lifters. You can run a heavier weight oil, 0w40 is more 30 than 40. |
11-23-2024, 02:21 PM | #9 |
Rep 1,035
Okey, thought it was directed to me as I was the only one mentioning them. It's not many cars that have solid lifters these days, the S54 was the last BMW engine to have it.
