      11-04-2024, 05:18 PM   #1
123Britt
Drives: 15 M235i AT; 2008 Z4 3.0Si MT
ESS -- $4 FIX for Rough Idle
OK -- So in my n52 I could see a little oil weeping from the ESS - and my car is running a little rough on idle & intermittent at that.
So after replacing spark plugs (NGK) and removed the 16 yr old Coils (66K miles). The poor idle remains.
Purchased ESS Seal and the Valvetronic Motor (Football Seal).
After replacing the ESS Seal (10mi Job). WoW!!! I must have had a bad vacuum leak.
As cheap as the ELRING ESS Seal Was $4.06 from FCP Euro --- and simple to remove -- I highly recommend.
      11-07-2024, 06:35 PM   #2
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Curious…because I’ve had a rough idle from was since initial install, and recently started to notice a little oil as well…do you have a part number/possible write up to go by?
      11-08-2024, 04:01 PM   #3
123Britt
Ordered from FCP Euro
ESS Seal was on FCP -- Removed with a Right Angled pick --- stuck into the side of the seal in about 3 places and pulled it out in no time. Ensured that the ESS sensor prongs and inside of Sensor (after 1st disconnecting the battery) was free of any oil / used alcohol on an Q-tip and wiped it out.
Good Luck. see Youtube
WickedNy227.50
      11-08-2024, 07:24 PM   #4
3002 tii
3002 tii's Avatar
2544
He’s referring to this part
https://www.fcpeuro.com/products/bmw-gasket-11127552280
Plenty of write ups online as it’s a common maintenance item, just google eccentric shaft sensor. Here’s one from YouTube
Follow for latest mods
WickedNy227.50
