08-29-2024, 10:16 AM | #1 |
Rep 1
Clutch not engaging
At wits end, 2004 Z4, sat dormant for 3 yrs before acquired yet did crank and drive, did hydrolic fluid change and bled brakes then clutch however due to accessibility issues screwed up and let all fluid bleed out of slave, have not gotten clutch operational since
Thus far have replaced fluid line from clutch master to resivore as well as both masters cylinders and slave, using pressure bleeder, repaired all the fluid leaks and will now stay pressurized Proble is that I am still unable to get resistance in pedal and cannot get clutch to engage, if depress pedal with pressure bleeder at 20lbs I get pedal resistance but at 0 I get none, clutch won’t disengage in either scenario I am at a loss, anyone have any suggestions |
08-29-2024, 10:43 AM | #2 |
14387
Rep 5,576
Your post is not clear to me.
Have you bled the slave cylinder on the clutch? When you open the bleeder on the clutch slave cylinder, and then depress the clutch pedal, do you get any fluid out? Official procedure is to remove the slave cylinder from the clutch, and put a special screw clamp on it and you completely screw in the rod from the slave cylinder. Then bleed with pressure bleeder, and then screw the clamp back a bit and in again, bleed again and repeat this a few times. To get the residual air out of the slave cylinder. My guess is that your slave cylinder is full of air (so no fluid in there at all). The bleeder sits in front of the cylinder, so it's diffucult to get that air out if you can't move the slave cylinder rod. Maybe, if you don't have that clamp (and can't rig up one) you might manually fill the slave cylinder by removing it, and dripping in fluid (in the bleeder hole or hose hole) while moving the rod by hand a bit, and then fit the cylinder in extended form, and then further bleed the system.
08-30-2024, 12:23 AM | #3 |
Rep 1,044
I've never remove a clutch slave to bleed if and it's worked fine but it takes some time and fluid to bleed the clutch slave, I've say around 1L if you use vacuum.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
08-30-2024, 05:46 AM | #4 |
14387
Rep 5,576
Neither have I, but I've also never had a completely empty one.
Normally to bleed and refresh the fluid, the clutch spring presses in the clutch cylinder (when clutch is depressed and then the bleeder is set open), but maybe it doesn't press it in 100% all the way, so if that's the case and it's completely empty, there's still air in there.
08-30-2024, 07:46 AM | #5 |
Rep 12,731
Garage List E86 Z4 M [10.00]
F15 X5 35i [9.17] F10 550i (Retired) [9.17] F25 X3 35i (Retired) [9.43] E85 Z4 M (Retired) [9.44] E82 135is (Retired) [9.56] E90 328xi (Retired) [9.25] E86 Z4 3.0si (Retired) [8.95] |
Definitely sound like you got air, a lot of it, in the line
08-30-2024, 11:52 AM | #6 | |
Rep 1,044
GuidoK14386.50 |
08-30-2024, 04:39 PM | #7 |
14387
Rep 5,576
That might be an interesting difference. The TS uses a pressure bleeder.
Maybe with pressure he's mainly pushing more air in the cylinder (and compressing the air that is already in there), and when releasing the pressure, the air pushes the fluid that managed to get in there out again. On the slave cylinder, the bleeder sits a bit on the underside and the cylinder is horizontal. Maybe that's not so suitable for pressure bleeding as a brake cylinder where the bleeder sits on top and the feed is at the bottom (well, more in the middle)
08-31-2024, 12:38 AM | #8 | |
Rep 1,044
I haven't tested a pressure bleeder yet, but I should get one as BMW uses one when the ABS needs bleeding. I've tried that procedure on my M2 with my vacuum bleeder and that haven't worked out or if I'm not good with ISTA (fails when I get to the front brakes).
