      04-11-2024, 08:09 PM   #1
solo the lad
solo the lad's Avatar
Drives: E85 Z4
N52 Carbon Intake Tube Completed!
Hello everyone, I am very pleased to announce I have finished the prototypes for the carbon fiber intake tubes I was working on for some months. I'll attach some pictures of it installed below. I am able to sell these to forum members if there is enough interest, which I expect there should be since they are absolutely gorgeous. The prototypes are a perfect direct fit replacement to the stock intake tube, made of 3k 2x2 twill pure carbon, giving a nice OEM+ look. The main benefit is obviously cosmetic, however there are a couple more as well. Air resonator box is deleted so you can expect a very slight weight savings and sound increase, along with a smoother air path, which should theoretically provide some power increase (I have yet to back this up with dyno tests, I will try to do that in the coming weeks). I currently only have one available for sale, but more will be available soon. Feel free to PM me if you're interested and we can work out a price depending on your location.
belcom227.50
MVRS15.00
      04-11-2024, 08:26 PM   #2
cbpip
Drives: BMW Z4C 3.0si 3 pedal
2007 BMW E86C  [10.00]
Interested, sent a pm.
      12-06-2024, 08:41 PM   #3
machikoo
Drives: BMW Z4 Coupe
Hello, I am interrested, is it still actual?
      12-06-2024, 09:40 PM   #4
gaseosx
Drives: E85 Z4 3.0i
Should PM him. Here is the classified listing:
https://www.zpost.com/forums/showthread.php?t=2106566
Something I didn't expect by installing it is that you don't need to remove your intake to install engine mounts anymore.
      12-06-2024, 10:22 PM   #5
Piper1
Piper1's Avatar
Drives: E85
How’s the sound in cabin with it and no sound generator piping to the firewall? Love the look but with just removing the baffling this year in the coupe it puts the shiteatin grin on the face.
      12-08-2024, 04:57 AM   #6
gaseosx
Drives: E85 Z4 3.0i
I have an 08 3.0i so it sadly did not have the sound generator out the factory. Hard to tell if it made a sound difference in my case as I did it combined with MILV's and new headers.
Piper1688.50
      12-08-2024, 05:54 AM   #7
Efthreeoh
Drives: Z4 Coupe & Z3 Roadster
The air box is tightly mounted to the wheel well via two rubber grommets. The engine is mounted to flexible mounts. I'd be worried about stress on the throttle body and air box. Resulting in eventual air leaks downstream from the MAF sensor.
      12-08-2024, 08:33 AM   #8
cbpip
Works fine, no air leaks. Have had it installed for months since April this year. No issues and eliminated the sound generator. Much cleaner look in engine bay IMO.
      12-08-2024, 11:01 AM   #9
Piper1
Piper1's Avatar
Drives: E85
What’s the sound in cabin difference with sound generator delete from stock to now?
Prior to removing the baffles I thought my e86 sounded too tame in comparison to my e85 with ess, racing dynamics headers and supersprint post headers. With the baffles out of the generator it brings similar smiles now on the stock e86 that the modded e85 does.
      12-08-2024, 09:57 PM   #10
cbpip
To be honest I really didn't pay much attention to the piped in sound. I listen to what the engine sounds are telling me rather than putting too much emphasis on the added sound into the cabin. With the sound generator removed it's one less concern for leaks. And it looks great in comparison to the stock piping.
Piper1688.50
      12-09-2024, 05:59 AM   #11
Huz-Z
Huz-Z's Avatar
If the car is designed to operate on a given airflow, and the computer is set to look for that, why is it that increasing the airflow without telling the computer about that in some way, doesn’t mess things up?
      12-09-2024, 10:38 PM   #12
cbpip
The MAF is prior to the pipe, no change in air intake flow and the original air box is unchanged. Doesn't act like a CA intake. Just a different tube without the sound generator on it.
      12-10-2024, 07:14 AM   #13
Huz-Z
Huz-Z's Avatar
I get it - thanks!
