      12-02-2024, 11:08 PM   #573
2544
Originally Posted by MYF30ROCKS View Post
Stock 06 M R
Will the following rims/tires fit on my Z4MR? any rubbing or too much stick out?
19x8.5 ET29 front 235/40/19
19x9.5 ET23 rear 265/35/19
Define “fit” lol. It’s aggressive but it’ll be close.
Issue is you’re running a tire size that’s 1/3” taller in combination with aggressive offsets. I can see it rubbing on compression, fronts by the bumper clip and rear at 12 o’clock.
Stepping down to 225/255 should help. Yes you have more rim exposed but running a wider square compound can help mitigate that. Or just do slight fender roll and add some camber.
