      11-27-2024, 05:09 PM   #1
j03chu
Drives: 08 SG/IR Z4MR | 07 AW/Blk Z4MC
07 Z4M Coupe AW / Blk Alum SoCal For Sale
USD 36,000.00
Feeler | For sale By Owner:
2007 BMW Z4M Coupe
Alpine White | Black | Aluminum | Navigation
83,930 current miles (may increase slightly)
$36,000 OBO
Everything listed below is included in the sale!
Current mods:
KW V3 Coilovers
Rogue Engineering Catback Exhaust
Rogue Engineering Transmission Mounts
Bimmerworld Engine Mounts
Eventuri Carbon Intake
Autosolutions Short Shifter Kit
BMW Motorsports Shift Knob
BMW Front Strut Bar
Motorsport Hardware Extended Lugs + 3MM Rear Spacer
Stubby Antenna
Black Kidney Grills
CCW Wheels LM20, 18x8.5 et35 and 18x10 et25, 6.5 inners and 2.0/3.5 outers in hyperblack on Continental Extreme Contact tires, 245/40/18 and 275/35/18 (currently mounted, 4020 front, 4218 rear age)
Titan7 TS-5 Wheels, 18x9.5 Square in black, 245/40/18 and 265/35/18 on Nexen NFera Sur4 tires + 2 x extra 255/40/18 tires (0119 age)
Standout maintenances done since 2021:
Valve Adjustment
Rod Bearings
Vanos
Rear Main Seal
Valve Cover Gasket
Spark Plugs
All Belts + Pulleys + Coolant Flush
Starter Replacement
Alignment + Brake Flush
5 x Oil changes in <5,000 miles since 2021
ALL service records in a large binder with manuals + window sticker
12V Battery replaced
Extra bits:
OEM Carpet Set (new)
OEM Trunk Carpet
OEM Shifter Console (unpainted, not installed)
OEM Car Cover
OEM Sunshade
OEM Strut Bar
OEM Rear Mudflaps (one side has a tear)
OEM Exhaust
Hawk Brake Pads (Set)
Brake Fluid
10W-60 Engine Oil
ZHP Knob
OEM Toolkit
Notable issues:
Aging front bumper clear bra (needs replacement)
Black vinyl roof (4 years old)
Washer cover + reflectors were painted Alpine White
Navigation is not working (need new CD?)
Scratches on shifter surround (needs refinishing)
3 x notable small rock chips on the hood
2 x total tiny dents on door / sides of car
Scratches towards the bottom of front bumper from normal wear & tear
Trunk driver side firewall carpet has a hole, previous owner may have mounted a sub
Driver side dash has a patched mounting holes, previous owner may have mounted a phone holder
Aging tires
Story:
First of all, I have admit that I am a bit of a Z4M fanatic, having owned three in the past. I owned a white M coupe from 2009~2016, a M roadster from 2018~2021 and another white M coupe from 2021 until now. I loved how these cars drive, their great engines, analog M feel and always loved the looks!
I have always compared the Z4M coupe and roadster as the poor-mans, affordable Porsche GT3 and speedster or the GT4 and Spyder. The coupe and roadster does drive quite differently and have different characteristics. The coupe is stiffer & sharper while the roadster is more compliant and exhilarating from the open top. Either way, both cars have fantastic hydraulic steering, 6 speed shifter and perhaps the best inline 6 motor ever made, the S54. The motor really likes to rev and provides a mechanical howl from the individual throttle bodies which exudes a charm that new cars just do not have anymore.
I bought this coupe with around 79,000 miles on it December of 2020 from a gentlemen in San Jose, California and this car spent its entire life in Southern and Northern California. Clean title, title in hand, full, major services and wear & tear parts are up to date. I bought this car with the intention of keeping it long term so a lot of preventive maintenance has been done. Rod bearing, valve adjustment, vanos check, seals, gaskets, radiator, pulleys, mounts (see service log), all done. There is also the owners manual, both keys, original window sticker and a binder of all service records between previous owners.
As you can see, more than $5,000 of important S54 related preventive maintenance was all done!
The car just had its smog & registration done 2 weeks ago and its last oil change at 83,925 miles. The car is tight, turn-key and ready to go.
Even though I would love to keep it, I believe I should allow someone else to have the pleasure of driving and owning this car. This is the last, analog, M car BMW has made, in my opinion. It is also time to move onto some P Cars!
Please see the Google Drive link below for more pics + info.
1. Images of the vehicle
2. Service Log
https://drive.google.com/drive/folde...8q?usp=sharing
Happy to answer any questions at j03chu@yahoo.com
(Please inquire for more detailed pictures or videos)
08 Z4MR | Space gray on Imola red, carbon trim
BC racing coilovers | Titan TS7
07 Z4MC | Alpine white on black, aluminum trim
KWV3 | CCW LM20 | Eventuri | Rogue Engineering short shifter, mounts and exhaust | BMW Motorsports shift knob | mudflaps | stubby antennas
      Yesterday, 01:57 PM   #2
j03chu
2025 BUMP before it goes on auction sites.
