      11-24-2013, 08:32 PM   #1
vachss
Drives: Z4 Coupe
Swapped Battery - Now AC doesn't work.
The OEM battery in my 3.0si finally died today so I swapped in a new one. Afterwards almost everything works (other than needing to reset date/time), but the climate controls are pretty much non-functional. Fan can be switched on an ultra-low setting, but that's it. No A/C, no rear window defogger. The car runs fine and all the other electrical systems seem to work normally other than this one problem. I checked the obvious fuses and didn't find anything blown.
Is this the "transport mode" I've heard about? More to the point, how do I fix it? I'm many years and miles out of warrantee and would REALLY like to avoid a trip to the dealer.
      11-25-2013, 09:44 AM   #2
vachss
Drives: Z4 Coupe
Doing some more searching it sure looks like this is "BMW transit mode" (folks on other forums had identical symptoms after bad battery replacement).
Unfortunately the solution (other than the dealer) appears to be hooking up a diagnostic computer to the car and resetting the programming. This can be done at home, but I know nothing about the INPA program and would probably have a better chance of screwing more up than fixing my problem.
So now I'll ask a big favor: Anybody in the LA area with a working copy of INPA willing to give me a hand?
      12-04-2013, 06:59 PM   #3
E85BMW
E85BMW's Avatar
Drives: 2006 M Roadster
Same thing happened to me when my battery died. A friend of mine was able to hook up his computer to my car and disable the Transit Mode. Unfortunately, I no longer live in California and I'm now in Florida.
I'm sure you'll be able to find someone in Cali, though. Good luck.
      09-22-2024, 01:29 PM   #4
BigMick33
Drives: Z4 2004
I have the same problem with my 2004 z4. Help!!
      09-22-2024, 04:37 PM   #5
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2004 X5  [8.50]
2018 Audi S3  [0.00]
Your answer is above - you need to disable transit mode as mentioned.
      10-08-2024, 06:13 PM   #6
NSummers
Drives: Z4 3.0i
I dont know if carly can do it, the foxwell scanner does.. fairly affordable ~150s.. same price dealer would charge to remove that..
-Nathan Summers
