      09-11-2024, 08:54 AM   #1
Don L
Don L's Avatar
Drives: 2006 Z4 3.0si coupe
Differential cover plug
Hi. I have a 2006 Z4 coupe si. This picture of the plug in the rear of the differential carrier. Is it a fill or drain plug? RealOEM doesn’t indicate.
Don
      09-11-2024, 04:55 PM   #2
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
2022 BMW X3 M40i  [10.00]
2011 BMW 135i  [10.00]
2007 BMW Z4M Coupe  [9.00]
1998 BMW M3  [0.00]
If there is only one of them it is both the drain and fill, will need to suction it out and pump in. (If there are two of them, whichever is higher off the ground is your fill plug )
I also see you are local to MN, welcome! Very few Z4 coupes here
      09-11-2024, 05:17 PM   #3
Don L
Don L's Avatar
Thanks. As I expected. I had the gear lube changed years ago. The location just seemed too high for a drain.
I believe I had the first non M delivery in Mn. BMW Motorwerks.
86Zed984.50
