06-27-2020, 11:32 PM | #1 |
Rep 12,565
Low Offset 9.5" Front Fitment?
Anyone running 9.5 et22 in the front (with 265 rubber)? If so, mind sharing suspension/alignment specs and what else was needed to get it to fit?
06-29-2020, 11:06 AM | #2 |
Rep 687
Drives: 06 Black Sapphire Z4MR
Following
I have enough issues dealing with 18x9.5 +20 on 245/40-18 RS4, the tires rub on the fender, bumper, and inner fender liner, mind you i am hoping to bring that back to +22 with my helpers removed, but I always have a fear of rubbing on my KWs on the inside Front Camber: -2.8
Revolution of our Times
I will return to the track, one day. |
06-29-2020, 01:51 PM | #3 | |
Rep 12,565
06-30-2020, 08:01 AM | #4 | |
Rep 687
Raising it did help in terms of rubbing on the fenders, previously I was for sure rubbing on metal, and first time I went out to track with this setup before I had my height adjusted, I was rubbing fender, fender liner, and even dislodged the front bumper every time I come off the track. basically what I learned is, more camber will help as long as you aren't touching the spring perches or the spring on the inside, so will height, but ultimately if you are lapping it, you will likely rub on the liner like I have.
06-30-2020, 10:32 AM | #5 | |
Rep 12,565
06-30-2020, 03:05 PM | #6 |
Rep 2,874
I don't think it matters. Even my sunken skinny stock 225/45-R18 tire (similar sidewall height as your 245/40R18) on stock wheel - ET42 have a slight rub in that area on compression!
07-10-2020, 12:07 AM | #7 |
Rep 104
I ran 9.5" et35 + 12mm spacer = et23 effective for a week or so with both 255 PS4S and 265 Trofeos, 3.2 degrees camber, 9 degrees / max caster. This setup rubbed fender liner at full lock + scrub radius increase didn't feel great and I went back to the 5mm spacer I usually use.
07-10-2020, 08:30 AM | #8 | |
Rep 687
What suspension setup you on and how low are you. Where are you rubbing on the fender liner. I am suprised you didn't rub on the inside at +30, I rub my coilover at +25 and im only on 245 tires.
07-10-2020, 06:47 PM | #9 |
Rep 515
I'm running 9.5 et 26 with 265's ....define fit. I've been running that size for over a 100k and am now back to maxed camber on stock suspension, fits with a bit of poke but no issues with anything but the front fender liner at the front edge of the wheel well. But that was done in years ago running slicks on the track so hard to say for sure if it would completely clear.
07-18-2020, 12:36 AM | #10 |
Rep 104
MCS 2-ways with 60mm 6" springs and very short Hyperco helper springs now, maybe .5-1" lower than stock (around 5.5-6" measured at front and rear jacking points) - wheel clears the strut by 5+ mm when I use 5mm spacers behind 9.5" et35, 265 Trofeos clear this setup too even with their fat sidewalls. Tbh I don't know how a perfectly stock, intact fender liner would clear this setup, mine has seen lots of rub over the years near bumper's upper mount point but almost no wear elsewhere closer to center of the car or behind the front axle line.
07-20-2020, 07:57 AM | #11 | |
Rep 687
Guess I just cut a bit more fender liner or raise the car a bit
07-29-2020, 06:47 PM | #12 |
Not a New Member
94
Rep 925
i'm a bit late to this party, but AriuSen here on zpost had square 10et25 and 265/35r18 for track. reverse engineering to a 9.5et22 shouldn't be too hard from that. Apex has some of his stuff listed through their gallery pages from before he sold the car. i am unsure of who owns it now.
sources: (suspension information in image captions through links below) Apex gallery Apex fitment guide ... (see the "Race Fitments" section) .
