      11-29-2023, 06:19 AM   #1
pcube
pcube's Avatar
58
Drives: Z4MC, G20 320i
Bilstein B16 PSS10 Z4M Info
Hey all,
I know there are several threads discussing this particular set of coilovers, but there are bits of information all over the place which requires some searching so thought I would share what I did. Hopefully it benefits someone in the future.
Some background. My car is entirely street driven (unlikely it will ever see the track), and my previous set of coils were H&R. They have been on the car for 6+ years and about 60k miles. I remember that they were quite comfy when they were first installed, but recently it seemed like there was zero damping which prompted my decision to have them replaced.
The correct Bilstein part number for the Z4M is 48-141635. I found that searching online using the part number gave me more results. I ordered mine from schmiedmann.com with a 10% discount. Delivery took about 3 months so I guess my set was freshly manufactured.
These coilovers require some original parts to complete the install, see below pics for reference. Of course, you can reuse your old ones but mine were in pretty bad shape so replacing them is strongly recommended. The parts I purchased were:
31-33-1-090-612, front spring plate with axial bearing (2 pieces)
51-71-7-036-781, front strut tower reinforcement plates (2 pieces)
31-33-1-091-233, front upper spring pad (2 pieces)
33-53-1-136-385, rear upper spring pad (2 pieces)
33-53-1-094-518, rear bottom spring pad (2 pieces)
Rogue engineering rear shock mounts - already had these, just had to buy new bushings which are really cheap.
The installation process is straightforward, nothing special to note. My workshop got the job done in less than 2 hours with two mechanics.
I have the damper settings at 3 all round and am pretty pleased. Ran the car through my regular routes with some long sweeping high speed turns and also tighter turns, everything held up well. Read some other reviews which said that the Bilstein coilovers are harsh. As far as coilovers go, I really don't see how much more comfortable they can be. Overall, very satisfied.
On to the pics... Btw, note the size difference for the rear shocks.
XMetal1093.50
      11-29-2023, 01:52 PM   #2
gnx
Όλα ρόδες
gnx's Avatar
728
Drives: BMW
Looks good. Are these M763 rims with F80 blue brakes? Do you have spacers up front?
      11-29-2023, 04:09 PM   #3
grannyknot
grannyknot's Avatar
933
Drives: 2008 Z4M coupe
Thanks for including the list of the stock parts needed, I also have the H&R set and I'm very pleased with it but all the original parts were discarded before I bought the car.
What springs are you using?
2008 E86 M coupe
      11-30-2023, 02:09 AM   #4
pcube
pcube's Avatar
58
The rims are replicas of the 763, spacers needed for the rear. Kinda difficult to find an original set where I am. Also, the front offset for original 763s may be a little too aggressive.
The brakes are stoptech, just painted blue
gnx727.50
      11-30-2023, 02:19 AM   #5
pcube
pcube's Avatar
58
Just the standard springs that came with the set. Never felt the need to upgrade for street driving.
For the H&R, the original parts required up front are the same as listed previously; while in the back there is no need for the lower spring pad (may not need the upper ones too but I am not 100% sure).
      12-01-2023, 03:10 AM   #6
Westersund
Westersund's Avatar
Sweden
461
Drives: BMW
I see that you still have the fender side roundels installed that you bought from me. Car is looking good!
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87
      12-01-2023, 06:11 AM   #7
mmm-five
mmm-five's Avatar
Drives: 2006 Z4MC + 2015 320D M-Sport
Same set-up I use when I swapped out the OE stuff at 100k miles. It was cheaper to upgrade to aftermarket than buy the compromised OE stuff, and I wanted something 60:40 road-biased (these or KWv3), than more track-biased (e.g. Bilstein Clubsport/Evo or KW Clubsport/Comp).
I decided not to lower the car too much as I have to negotiate a lot of speed humps and the car would already touch some of these at OE height, and my e34 M5 (on Bilsteins as well had already lost one sump due to them).
I have mine at 4-5 in the summer, and 1-2 in the winter (if I remember).
For Nurburgring it's 8 if it's dry and 4 if it's wet. For smooth UK circuits I just crank them all the way up in the dry and only take it down to about 6 if it's damp.
But it's purely personal preference.
      12-01-2023, 10:06 AM   #8
pcube
pcube's Avatar
58
Those aren't ever leaving the car haha
      12-04-2023, 02:29 AM   #9
pcube
pcube's Avatar
58
Just curious, how discernible are the settings? Does each click result in a significant change in characteristics? Noticed you only have 2 clicks difference between summer and winter settings.
I had a set of HKS coils on a previous car that was set up for the track, and honestly I could barely tell the difference so just ended up leaving it at the maximum stiffness.
      12-14-2023, 12:13 PM   #10
mmm-five
mmm-five's Avatar
1 click I couldn't really tell, 2 clicks I 'think' I can tell, but I had it on the lowest setting for quite a while to get used to it and kept cranking it up until it felt too poor a ride for UK roads and cranked it down a couple.
For winter - where I don't use it a lot anyway - I just took it all the way down and tried to keep the front/rear variance the same.
Some people just crank them to 10 for all their uses, but mine was a 90% road car for a long time (25k miles a year) and the UK tracks I used were very smooth, so didn't hamper the higher settings. The bumps/kerns at some places on the 'Ring mean I back off a little to avoid too much bounce.
      02-09-2024, 09:42 PM   #11
onebluemcm
onebluemcm's Avatar
33
Drives: '07 Z4MC
Wanted to say thanks for this. Getting ready to install the same coil overs on my 07 M coupe. 30% off, yep, good time to pick up a set.
To the OP, pcube, what wheel size, offset and tires size when you did this install?
I have 18x9 +38 offset front, 18x10 +27 offset rear with a 245/40 front and 285/35 rear tire. It's on Koni yellow struts/shocks (older Ground Control kit) with Dinan springs, all this stuff was put on probably 10 years ago. The springs I believe are supposed to be a very mild drop, I want to say 3/8"/10mm IIRC.
I've had rubbing from the inside of the rear tires on the upper vertical part of the wheel well liner. Nothing toward the outside near the fender. And I think I am not running enough rear camber based on tire wear pattern, which makes me even more concerned about where the rubbing is happening. Was wondering about your wheel/tire combo for comparison.
<img src=http://i284.photobucket.com/albums/ll30/onebluemcm/RG63_08-1-1.jpg border=0 alt= />
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=|
Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo)
RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint
