05-08-2020, 01:50 PM | #1 |
Rep 4,106
Water softener valve
Just found out my house has a water softener which I never uesed before...lol
Well the issue is I don't know what position the valve is and I can't turn it at all. Just wanted to make sure I don't break anything. How do I know what state the system is? How do I turn this damn valve handle? Thanks! https://ibb.co/sw8tB9n https://ibb.co/n3SZpZT
05-08-2020, 02:22 PM | #2 |
Rep 5,728
Drives: 2019 M2 Competition
Left loosy righty tighty...that's all i got.
05-08-2020, 02:26 PM | #3 |
Rep 1,004
From the Kinetico.com website:
We're happy to help you in any way we can. If you have questions, comments, praises or concerns, we'd like to hear from you. Here's how to get in touch: 24-Hour Support 1-800-944-9283 or Email Customer Service |
05-08-2020, 05:42 PM | #5 |
Rep 4,821
You will need to get it serviced. Filters need to be re-bed every 2 years and softeners every 5-7 years. I’d get it serviced before flowing water through it into your house and hot water heater.
I assume there is a tank / canister nearby to fill with salt?
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
05-08-2020, 07:50 PM | #6 | |
Rep 4,106
I have the salt filled and was able to run the system but still can't figure out how to turn the valve...lol Not so important at the moment but still bugs me. |
05-08-2020, 08:35 PM | #7 |
Free Thinker
16892
Rep 7,454
Mine is vertical when in use and shows green under the notch in the valve handle.
05-08-2020, 08:39 PM | #8 |
Rep 4,106
05-09-2020, 12:26 PM | #9 |
Rep 2,770
I would expect that you should see a symbol where that arrow is pointing that corresponds to the three states listed on the valve body. Yours appears to be in an indeterminate state either past the allowed rotation or in between settings. If it is jammed I would leave it alone and contact a plumber who knows about those valves. Best not to mess with it and result in disabling the water supply to your house which would result in an emergency call to a pulmber.
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!! 2011 e92 X-Drive Coupe - SOLD!! |
09-03-2020, 12:18 PM | #10 |
Guest
Rep n/a
Drives:
Dude, I recommend you don't try to fix it by yourself. You can add more troubles. It will be well, if you call the plumber from a reliable service and he will do diagnostic. After I had read a lot of stories about these filters and how do they are difficult collected, if I have any questions I always write in support of water softeners San Diego. Well that it works anytime and they provided me very long guarantee on my filter. I think that it is easier than to look for breakages by yourself. Hope that you have sorted out
