05-09-2012, 12:37 AM | #1 |
Rep 68
Just got an external mic for the GoPro...
And wow does it make a difference. I mounted it to the rear bumper right above the exhaust, and this is what I got from a run through the first two gears. Keep in mind that this is a bone stock exhaust on a non-M Z.
I got the mic on Amazon for $68. http://www.amazon.com/Audio-Technica.../dp/B0016ARZ9C I should preface all this by saying that I did a quick test of the mic inside the car, and it didn't pick up much sound at all. I've already removed most of the foam from the sound generator tube and bolted on an intake, so it's not like it's all that quiet inside the cabin. I'll try putting it closer to the footwell to maybe pick up some more sound, and post up a comparison between the internal and external mic when I do. I'll also be giving it a go on my motorcycle with a race pipe later this week. Can't wait to hear what that'll sound. |
05-09-2012, 11:13 AM | #2 |
The Commissioner
23
Rep 137
That sounds really good!.. Did you leave the Gopro out of its case to plug that mic in? Or do they make a special case that has an opening over the mic jack?? I also have a Hero HD 2 and my biggest gripe is the sound and the location of the External mic jack... And another question that Mic you bought does it come with a long cord? It looks short on Amazon?
05-09-2012, 12:01 PM | #3 | |
instagram 997turbotom
279
Rep 7,377
05-11-2012, 01:03 AM | #4 | |
Rep 68
05-11-2012, 11:41 AM | #5 | |
The Commissioner
23
Rep 137
05-11-2012, 12:52 PM | #6 | ||
279
Rep 7,377
05-11-2012, 04:56 PM | #8 |
Rep 335
Drives: ae86; z4mc
very cool.
Im thinking of sticking one under the hood for some engine noise: |
05-11-2012, 07:12 PM | #9 |
Rep 68
05-12-2012, 02:34 AM | #10 |
Rep 68
I did a comparison between the Audio-Technica Pro-24CM ($68) and the Audio-Technica ATR-3350 ($23). Looks like I'll be returning the former, because I really can't hear enough of a difference to justify the extra $45.
05-14-2012, 11:03 AM | #11 | |
Rep 4,128
Drives: M235i & G30 540i
Hey I have a Hero2 as well and have been trying to get that exact location for filming inside the car. Where exactly did you mount the camera and what did you use the GoPro suction mount? Thanks
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
05-14-2012, 11:13 AM | #12 | |
Rep 68
As you probably noticed, the suction mount vibrates like crazy. After some googling, I found out that for non glossy-smooth surfaces, you need to prepare the area by heating it up a bit, so I cleaned the area with acetone and used a hairdryer on the spot for about 30 seconds (and heated the mount itself for another 15) before sticking it on. I then let it sit for 24 hours without using it. It seems to have worked, because now it's rock solid. |
05-16-2012, 01:59 PM | #14 |
Rep 222
you can also get pretty good sound with the gopro mounted about 4-5 inches from the intake inside the grill...
2007 3.0si Coupe
Dinan Stage I Suspension (Shocks, Struts, Springs), Ground Control Front Camber Plates, Treehouse Racing Front Control Arm Bushings, RTAB Bushing Limiters |
08-12-2012, 08:59 AM | #15 |
Rep 844
hey I just got the same mic as you. What did you use to connect it to the rear bumper? Did you mount it right near the license plate? Going to VIR in two weeks so I should get some good footage.
09-04-2012, 09:53 PM | #16 |
Rep 12,565
Bump - can you show me where exactly you placed the mic, and how did you secure it?
09-04-2012, 10:22 PM | #17 | |
279
Rep 7,377
mine's right in the middle of the rear, about 1" below the trunk opening line. I have the line going through my trunk, and painter's tape keeping it from dancing around near the back bumper. Also have a very small foam muffle over it
