08-10-2013, 08:26 PM | #1 |
Rep 291
Fast blinking / lamp warning light on - can't turn off
My lamp warning light came on this afternoon on my 06 z4m roadster and the left turn signal began signalling faster than normal. Upon inspection, a part of the brake light bulb broke off, which is probably what threw the code. I have replaced the bulb and the light still says.
I have tried(and have not been able to get the light to go away: -swapping all bulbs from left to right -tried removing a bulb from right side to see if it would signal fast as well, but it continues to signal normally with bulb removed. -headlights and the circular light in the headlight are functional. when I turn on the highbeams, the lights will flicker but the same projectors (outer) will light up. the inner projectors never turn on. Do the hi-beams use the outer or inner projector of the headlights? -removed led license plate lights with oem bulbs Is there a way to reset all the dash lights? This is the light - 2nd row, 3rd image http://cdn7.staztic.com/app/a/575/57...-s-307x512.jpg Last edited by brandobot; 08-10-2013 at 08:59 PM.. |
08-10-2013, 10:47 PM | #2 |
636
Rep 3,124
Here's an explanation of the headlights.
Threw me, too, when I first got my car. High beams are via a mechanical "eyelid". The license plate lights are not monitored. I think you still have a bulb out somewhere. Make sure all 4 front turn signals are flashing. There's 2 on each side. 5 and 6 in the diagram.
08-11-2013, 12:06 AM | #3 | |
Rep 291
Thanks. I"ll check the turn signals. I can't tell from the diagram, where are the two turn signal bulbs in the front?
