      10-10-2012, 09:27 PM   #1
jehsautosalon
Drives: z4 m roadster
horn not working.. fuse is good!
It just so happen that my horn stopped working and all this time i thought it was the fuse but its not.. hmmmm???!!
      10-11-2012, 10:44 AM   #2
gferil
gferil's Avatar
30
Drives: 06 Z4MC
If the fuse is good, the horn itself could have gone bad or disconnected, check the connections on it to make sure everything is seated properly. If they are, then remove the horn and "feed" the connectors power from a separate power source to see if it's working properly.
If it's still working, then maybe the plate behind the airbag got loose and when you push it in it isn't making proper contact to the rest of the circuit to complete the loop, so disconnect the battery, remove the airbag, and tighten down the screws to the horn plate and then put the airbag back on and reconnect the battery and test it out.
If all that doesn't work...then I have no idea...
      10-12-2012, 01:23 AM   #3
jehsautosalon
thank you sir! i will figure it out!!
      12-29-2012, 01:58 PM   #4
jehsautosalon
Do you know where I can find the horn? I can't find it sir
      12-29-2012, 03:28 PM   #5
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Here's a picture, looks like it's behind the right front bumper.
      12-29-2012, 05:07 PM   #6
jehsautosalon
Thank you so much Finnegan!
      12-29-2012, 05:46 PM   #7
Drives: M2 Comp
On the M there are two horns.
IIRC there is one on each side.
