03-25-2012, 06:52 PM | #1 |
Rep 61
Add-a-fuse
Has anyone had success adding a fuse to their fuse panel? If so, how did you do it and do you have any recommendations or a How-To?
I'm specifically looking to add a cigarette lighter jack so I can semipermanently add a power source for my Bluetooth A2DP stereo gateway. This is the setup as I currently have it: Since the fuse panel is located behind the glovebox, I figure I can add a cigarette lighter and move the cigarette/USB adapter and the gateway behind or into the glovebox to clean things up a little. However, I've got pretty limited experience with car electronics and I don't want to mess anything up. Any advice would be greatly appreciated. Thanks in advance. |
03-26-2012, 08:31 PM | #2 |
More of this than that!
29
Rep 817
I too am thinking of adding something like this to add power for other 12v additions such as phone charger, gps, tablet, etc.
A clean install with hidden wires is a must for me. No muss no fuss clean and tidy!
'06 Z4 3.0i Jet Black/ Biege/Black Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector |
03-26-2012, 11:07 PM | #3 |
Rep 892
I added a dual fuse thing into a single slot for my Passport SRX radar detector. I just located the proper amp on the panel (behind glove box), and plugged the adapter in with two of the same fuses and was good to go. Took maybe 1 minute total. You can run your wires where ever you like and it's all hidden.
When looking for the proper slot (amp wise), make sure it has power when you want it to (For example, when key is turned to accessory mode or engine on... You don't want a fuse that has power when the car is off, then your added accessory will always be on and kill your battery). I used something like this: http://www.autozone.com/autozone/acc...ier=32416_0_0_ (about $7) You could also create a new slot, but that's a whole different story and much more work. |
03-27-2012, 05:50 PM | #4 | |
29
Rep 817
Excellent information....might have to see if this weekend I can get another DIY off my list.
03-27-2012, 10:09 PM | #5 | |
Rep 238
If its a radar detector, you can ten run the wire out if the glovebox and up the A pillar and across to the rear view. Tuck the wire under the trim with your fingers and you have a hard wired detector installation with no cuts, holes or stripped wires. |
03-28-2012, 02:47 AM | #6 | |
Rep 61
03-28-2012, 11:17 AM | #7 | ||
Rep 892
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i |
03-28-2012, 12:27 PM | #8 |
Rep 238
03-29-2012, 09:25 PM | #9 |
Rep 61
So I picked up the parts and tried the install yesterday.
Here are some pics: Parts: 10amp fuses, 12volt outlet, add-a-fuse Cigarette lighter wired up. Lighter and add a fuse Ground Add-a-fuse in place--in the cigarette lighter fuse. Aaand the final result.... it didn't work. I'm not sure what I did wrong. I checked my wiring several times, switched the ground (black wire) and live (red) wire, and tried a few different fuse outlets. The appropriate function in the car works, so I assume the add a fuse is ok, but the auxiliary cigarette lighter doesn't work no matter what I do. Do you think I need to use a higher amp fuse? Do you think I got a bum cigarette lighter? Any advice would be great. |
03-29-2012, 09:39 PM | #10 |
Rep 1,001
As one of the post above mentioned, you are probably tap into the "engine on only" source so turn the car on and see if it work. The best thing is to get a volt meter to check the spare slots and pick the approriate one ( always on, engine on only, some cars even have just empty slot)
03-30-2012, 08:51 AM | #11 | |
Rep 61
This leads me to suspect the problem is either that I don't have a high enough rated fuse to power the 12Volt lighter (which I don't think is right because the fuse would blow if I was trying to run too much electricity through it), the lighter is defective or my connection to the lighter is installed incorrectly. But again, I have zero experience with electrical stuff beyond changing light bulbs, so I'll take any advice I can get. |
03-30-2012, 09:27 AM | #12 |
Rep 1,001
I am not sure what the hell is going on. I did this on multiple cars and never have any problem. I am suspecting you have an incorrect ground connection. Make sure the ground (black wire) is connecting a solid ground point (connected all way back to the chassis or engine block)
03-30-2012, 09:48 AM | #13 | |
Rep 61
I knew I shouldn't have dropped out of engineering school in college! |
03-30-2012, 10:01 AM | #14 |
Rep 1,001
Hope you will figure it out. looking closer at ur picture, the black wire appeared not connected to ground (since there are many plastic parts around that area). good luck
03-30-2012, 12:42 PM | #15 |
Rep 892
Choose a new ground spot. Also, do you have two fuses in the dual fuse thing? It needs one for the original spot and another for whatever you're adding; same amp.
03-30-2012, 03:16 PM | #16 | |
Rep 61
Is there anything near the fuse panel that I can use? I read (either on this forum or somewhere else) that the screw right by the fuse panel is a good ground. I'm going to get a ring connector thing for the ground, too. It might give me a better connection. I'll try to mess around with it a little after work. |
