      05-14-2022, 09:25 PM   #1
jmilt13
jmilt13's Avatar
19
Drives: 3.0si Coupe
Any current available alternatives to BlueBus?
Bluebus looks like the perfect solution, but not readily available. Anything on par with this solution?
Thanks
      05-15-2022, 01:50 AM   #2
Clearancediver
Drives: 2004 Z4
Try a bluetooth auxiliary adapter off of eBay….. I just ordered one to see if it will work. This is just curiosity to see if they work as I have Bluebus installed. Got intrigued after a conversation in another thread. I had a Sirius Car radio plugged into my aux at the moment…. when I want to travel in the US or here in BC outside of cell coverage. A months Sirius charge is waaay cheaper then International roaming charge………..
Sent from my smart phone...
      05-17-2022, 11:42 PM   #3
Polarbert
English Member
25
Drives: 2006 Z4M Roadster
The thread above yours in this forum section links to something that appears very similar. I'm going to give it a try. Coolpro it's called.
      05-22-2022, 11:57 PM   #4
Polarbert
English Member
25
https://www.zpost.com/forums/showthread.php?t=1913272
      05-23-2022, 05:35 AM   #5
Coi
Drives: 21 X3 M40i, 07 Z4MR
I have a Grom unit in my car that replaces the multi CD changer in the trunk. Works fairly well. I'm not sure exactly which unit it is because previous owner bought it but I can check the service records to see if it's there. Their products do seem to be readily available.
If you have the 3.5 mm AUX jack under your dashboard you could get a very small bluetooth adapter and plug it into the 12V port near the shifter for power and into there for sound. Not the cleanest looking solution but functional. I think only later cars have this AUX jack but I'm not sure. I know someone who has a NC2 Miata with a 12V port and AUX jack next to each other and it works really well and doesn't look too bad with the cable neatly coiled.
