      02-23-2017, 03:26 AM   #1
antennahead
antennahead's Avatar
Drives: 2007 Z4MR silver grey
can't find part
Hey guys, I'm looking for the part number for the drivers side aero flap that's in front of the rear wheel. I've searched all over Real OEM and can't find this sucker. Mine got ripped off by a speed bump. This pic is of the part on the passenger side. Any help is appreciated.
      02-23-2017, 07:29 AM   #2
z4chick
z4chick's Avatar
Drives: 2006 BMW Z4 3.0si
Is this it??
http://www.realoem.com/bmw/enUS/show...62#82160151582
      02-23-2017, 08:10 AM   #3
Steeler
Steeler's Avatar
2429
http://www.realoem.com/bmw/enUS/show...diagId=51_4952
Items 10
      02-23-2017, 03:20 PM   #4
antennahead
Originally Posted by z4chick View Post
Unfortunately I think those are accessory like mud guards, not the factory installed aero flap, but thanks for trying
      02-23-2017, 03:21 PM   #5
antennahead
Originally Posted by dbarton62 View Post
Thanks, you've nailed it. I looked at that parts section more than once, if only I had clicked on the little camera that has a pic of the part I might have found it
      02-23-2017, 03:59 PM   #6
Steeler
Steeler's Avatar
2429
Seems awful cheap and very unlike BMW to charge so little
      02-23-2017, 04:14 PM   #7
antennahead
I hear ya, it's always a good shock when something like this doesn't cost $100
Update: The part is actually $37 now at ECS versus the Real OEM listing of $13. Here's the interesting thing as to why I don't think I could find it. The part is listed for every variant of the Z4 EXCEPT the Z4 M. When I plug in my serial number the part is greyed out under the Wheel arch trim, rear, and only shows for the 2.0 through the 3.0 versions of the car. Did those models have this aero piece as well? For some reason I thought this was an "M" addition for aerodynamics, but a picture search of Z4s shows some with it and some without.
      02-24-2017, 01:22 PM   #8
Steeler
Steeler's Avatar
2429
Not sure, seems more of a gravel/mud flap than an aero piece
      02-24-2017, 02:57 PM   #9
antennahead
Except that it is in front of the wheel. My indie mechanic, who used to race professionally, told me it was an aero piece ......... not that he is the expert Anyway, that's quite the price hike in 10 years.
      04-11-2017, 10:13 PM   #10
antennahead
Update to this posting. Replaced the part today. Did not have to jack up the car. It's held in place by 1 nut, 1 screw, and a push in plastic rivet. After removing the two visible retainers (screw and rivet), you pull the lower part of the fender liner out (released by the rivet removal), and this allows you access to the 3rd fastener, a bolt under the liner. Took all of about 15 minutes. Should you accidently rip off your rubber aero deflector like I did with a speed hump, this is a cheap easy replacement process.
John
