09-27-2011, 09:18 PM | #1 |
Rep 1,530
Check CD Error
Most of the time I use my CD player, I get a \"Check CD\" error and the cd won\'t play. None of the buttons work except the mode button. I can\'t even eject the CD. I was told by the dealer this only happens with burned CDs. Is this true? Does the BMW Certified Used and warranty cover the CD player? I\'ve got the premium sound system. Point is probably moot since I eventually want to change the head unit or get a Dice II MediaBridge. But if the CD player won\'t work, I\'m more apt to get a head unit instead. I need the CD player to listen to lectures.
Thanks.
09-27-2011, 10:15 PM | #2 | |
Rep 820
Drives: 2007 Z4MR silver grey
09-27-2011, 10:23 PM | #3 |
Rep 1,530
What program are you using to burn the CDs? I'm using iTunes. Do you burn your CDs at the fastest speed possible? Maybe it's the CD I am using.
09-27-2011, 11:05 PM | #4 |
Rep 820
It's a program called "Easy CD-DA Extractor"........... uses the LAME software for encoding MP3. I am using VBR, which sometimes is harder for certain players to read than a constant bit rate.............. and the Z has zero issues with them. I also burn at a fairly high speed, usually let the software set it. I have a HP that does the lightscribe label thing, so mostly use Lightscribe blanks by either memorex or verbatim.
09-28-2011, 01:36 PM | #5 |
Rep 1,530
Let me try burning MP3 CDs. I've been playing burned audio CDs. Thanks for the tips!
09-29-2011, 12:50 AM | #7 |
Rep 1,530
Regular CDs play but those are the ones I have been getting the "Check CD" errors. Where's the Aux hole in these things? I don't see on in the front of the unit.
09-29-2011, 12:28 PM | #9 |
Rocket Scientist
Rep 72
Drives: '08 M Roadster
I tried out an mp3 disk in my '08 M Roadie with the DSP audio system. I burned it at home using Nero to burn the data cd and lightscribe the label. When I put the cd in the player with the car parked, everything worked like described above: music played, song title, artist & album title. This morning as I was driving to work, I started getting all sorts of spurious noise hits at random times out of the system. Any ideas what could cause short-duration noise spikes? I don't think it's tied to bumps in the road because it happened on smooth roads as well. Is there a maximum bit rate for playback? The mp3s I burned vary in bit rate from 96 to over 300 and it seemed the lower bit rate mp3s played cleaner than the higher ones. It may just be a problem with my audio system because a store-bought audio cd had some weird noise issues, too, just not nearly as frequent.
2008 ///M Roadster
09-29-2011, 12:42 PM | #10 | |
Rep 1,530
I'm envious you guys have track names showing up. This might be an iTunes issue. I'll have to try out Nero and see what I get. |
09-29-2011, 12:43 PM | #11 |
Rep 1,530
09-29-2011, 07:13 PM | #12 |
Rocket Scientist
Rep 72
Have you turned on the text label function? When I first put the disc in, there were no track names showing. I turned on the text labels (one of the 2 buttons in the center of the panel below the cd slot) and boom, there they were. I also went to split screen on the nav system so I get the track info on the left & GPS position on the right. Also, if you press the far right button (under and to the right of the select knob) you get a menu screen that allows you to select random play mode on the disk.
2008 ///M Roadster
09-29-2011, 08:10 PM | #13 | |
Rep 820
09-29-2011, 08:52 PM | #14 | |
Rep 1,530
09-30-2011, 06:50 PM | #15 | |
Rep 238
09-30-2011, 11:26 PM | #16 |
Rep 820
10-01-2011, 04:28 PM | #17 |
Rep 1,530
How do you turn it on for a business cd player? I've tried all the buttons and can't seem to get the tag info to display.
10-02-2011, 11:10 AM | #18 | |
Rep 238
Could this be true with M's or is there somewhere else I need to go. |
10-02-2011, 12:04 PM | #19 | |
Rep 820
10-02-2011, 03:28 PM | #20 | |
Rep 1,530
Hmm... I'll have to look for that info button. I'm pretty sure I don't have it. I'll take a pic of my CD player and post it up if I don't find it and we can compare head units. |
10-02-2011, 10:01 PM | #21 | ||
Rep 238
10-13-2011, 09:07 PM | #22 |
Rep 1,530
I don't have pictures to post but I definitely don't have any info button on my head unit. I've burned some MP3 CDs and they play more regularly than audio CDs. I've only had an MP3 CD give me the Check CD error 3 times where as with audio CDs, about half the time.
