      01-26-2009, 03:26 AM   #1
Tooky
Drives: Z4 Sterlinggrau / 2.2L / 2004
Z4 Phase 1 : Reduce door noise
Hi,
So it's may be a stupid question but the noise when you closed the door in Z4 phase 1 (before 2006) is not really pleasant , and that was corrected on phase 2, someone knows which modification has been done on the doors : Acoustic foam, door seal, ... ? Or some would have an idea to reduce the sound ??
      01-26-2009, 08:36 AM   #2
epbrown
epbrown's Avatar
There were write-ups on this back in the day. Mostly, you just remove the door trim and add a layer of Dynamat or a similar product. That's pretty much all the factory did.
