03-27-2023, 09:10 PM | #1 |
Rep 410
Fan that turns on after shutting car off
I have an 07 Z4M. I've noticed over the years that sometimes, after shutting the car off, a fan starts up a few moments later and stays on for 10-30 seconds. I always assumed it was the oil cooler or something, never gave it much thought.
Today, the fan turned on and stayed on for several minutes. It was a beautiful, 70 degree day in California, so not particularly hot. I had thrown a code (P0012) while driving on this trip - that will be it's own thread later on as I sort through that - but I'm curious what this fan actually is? I confirmed it's not the radiator fans - they were not moving. A lot of hot air was blowing out from the front part of the car with the hood popped - is it the heat/air system for the cabin, and if so, why would that come on after the car is turned off? Did some searching but came up empty. |
04-17-2023, 09:05 PM | #2 |
703
Fan turning on happens to me quite frequently even on somewhat cool days given the slight incline and load of the highway near home. I really don’t think it’s abnormal. I’ve noticed this behavior across three different Z4m and one M3. Camshaft code is likely separate.
Reborn_298.00 |
04-18-2023, 07:33 AM | #3 |
Rep 410
I figured as much, thanks for responding. I do have a very steep hill leading to my house, so that could be the reason. I'm curious what the fan is, do you know? I didn't see the radiator fans spinning, so now I'm curious.
For the code, I've got the Beisan VANOS solenoid en route, hoping that takes care of it. |
04-21-2023, 09:09 PM | #4 | |
703
Unfortunately I don’t know where that fan is. The idea of a finger “finding” it while looking/listening has made me less curious. 7/10 times if I restart the car momentarily it turns off. Since I put it back on the charger I don’t worry much about it running a bit these days - no error codes and I’m happy! |
04-22-2023, 05:26 PM | #5 |
Rep 410
Yea I'm not concerned enough to spend time on trying to find a fan either . I just became pretty curious if anyone out there knows more about it.
Swapped the solenoid yesterday (and did all the Beisan recommended cleaning and o-ring change outs) and reset the ECU. I just took a small trip around town, maybe 10 miles, and it seems to have done the trick - so far so good. |
04-23-2023, 03:36 PM | #6 | |
703
Reborn_298.00 |
