      07-26-2008, 02:24 PM   #1
hart07
Drives: BMW 640i f13
How to remove the Bulb for the LIcence PLate ?
I want to change the bulb ( w5T10) for the licence plate, but i don't know how to do.
My car is a bmw z4 coupé 3.0 si
i see a plactic item but i don't want to break it.
Thanks to give me more info.
      07-26-2008, 04:39 PM   #2
DannyZ
Sergeant Major
DannyZ's Avatar
Drives: 03 BMW Z4 3.0i
you need to stick a standard screwdriver in the notched sides of the plastic base of either side there is two bulbs back there(be carefull here almost every one of these is heat rotted and it will break easily...) pry down gently until it is out of it slot and then you have to wiggle it horizontally which will "unhook" the tabs. to put back do everything here in reverse order...also it easier if you take your plate off first.
[SIGPIC][/SIGPIC]Z3 Z4 and someday Z8...
