03-19-2020, 04:55 PM | #2025 |
dances with roads
4732
Rep 4,096
A bunch of stuff related to clutch, driveshaft, and shifter. See post here.
03-19-2020, 06:53 PM | #2026 | |
Rep 1,794
Drives: E86 3.0si
wdb4732.00 |
03-20-2020, 07:44 AM | #2027 |
Get off my lawn
932
Rep 1,159
Drives: 6MT
Garage List 2023 GR Corolla [0.00]
2022 BMW X3 M40i [10.00] 2007 BMW Z4M Coupe [0.00] 2002 BMW 325xiT [0.00] 1991 BMW 318is [0.00] |
Some items to refresh the car ahead of spring and the summer track season. |
03-22-2020, 08:52 PM | #2028 |
Rep 1,689
03-23-2020, 12:09 PM | #2029 |
Rep 267
Drives: 2006 Z4 M Roadster
I converted my headlights from halogen to LED all-in-one units, I.e., PWM decoder, fan, LED driver. Wow what a difference!
03-23-2020, 05:24 PM | #2030 |
your average JAMF
3101
Rep 4,094
^^ are you sure you're not blinding oncoming traffic? Everything I read (other than from sellers) says that LEDs into halogen housings is a bad, bad idea, and also not street legal. You might want to test the glare situation by having someone you know drive towards you in the dark and see if they experience severe glare or not.
'21 M2 Comp
'19 Golf R |
3002 tii2284.50 |
03-23-2020, 07:51 PM | #2032 | |
Rep 267
wdb4732.00 |
03-23-2020, 09:28 PM | #2033 | |
your average JAMF
3101
Rep 4,094
It’s also very easy to buy so-called “HID kits” and “LED bulbs” for halogen headlamps and fog lamps, even though they’re unsafe and illegal. Most drivers don’t realize the sheer complexity of headlight beams in terms of the right amounts of light that must be directed toward certain angles for the best visibility and yet away from others so you don’t dazzle other drivers. Full interview with Daniel Stern: https://drivingintherealworld.com/pa...-daniel-stern/
'21 M2 Comp
'19 Golf R |
03-24-2020, 08:01 AM | #2034 |
Get off my lawn
932
Rep 1,159
Drives: 6MT
wdb4732.00 |
03-24-2020, 09:55 AM | #2035 |
Rep 376
03-24-2020, 11:49 AM | #2036 | |
Rep 267
The low beams have a very clear cutoff when used in halogen housings. I adjusted the vertical alignment so that the upper part of the beam is at the headlight height at a distance of 25 ft. This is actually more conservative than is typically accepted where the beams hotspot is aimed at headlight height at 25 ft. After setting things up I pulled into my street and walked about 200ft away to view and was not blinded. I’m comfortable that it’s set up correctly and not blinding other drivers. |
03-24-2020, 02:49 PM | #2037 |
Rep 40
Drives: 2003 bmw z4 3.0 6 speed
Clutch converstion kit, front supsension kit.
03-29-2020, 10:16 AM | #2039 | |
Rep 12,565
03-29-2020, 10:26 AM | #2040 | |
Rep 12,565
03-30-2020, 10:46 AM | #2042 |
AKA No_Dominion
174
Rep 158
Drives: 2007 Z4M
Got quite a few things purchased and mostly installed over the last week-ish...
Something I've been wanting for quite a while, the Evolve CF Airbox: Also: - RPI mufflers installed (holy crap, what a sound...) - Valve adjustment and rod bearings replaced - Strong Strut firewall/strut braces ordered So all in all, it's been a car-focused last couple of weeks, haha.
Evolve CF CSL Airbox /// SGT Headers /// DKF Resonated S1 /// RPI Mufflers /// Underdrive Pulleys /// Alpha-N Tune Mstache /// CF Side Extensions /// Skyer CF Rear Spoiler /// CF Engine Cover /// Strong-Strut Braces H&R Coilovers /// MRR GF7 Wheels /// PS4S /// Remote Start /// Rennline Pedals Last edited by No_Dominion_2; 03-30-2020 at 07:17 PM.. |
03-30-2020, 08:56 PM | #2043 |
Rep 12,310
Currently focusing on getting the garage itself. Got the week off so I've been painting the walls, putting together a Craftsman cabinet I bought a few weeks ago from Lowe's and organizing all my stuff. Eventually I'll get to overhauling my Roadster. Until then, you can see her in the background patiently waiting her turn.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
03-31-2020, 06:12 PM | #2044 |
Rep 267
Replaced the two upper O2 sensors. No errors but BMW recommends replacing at 100k miles. My car is at just over 219K miles.
It may be a placebo effect, but on my test drive it felt like it had more pull to it than previously |
03-31-2020, 06:17 PM | #2045 |
Rep 3,004
Wowie!
This is incredible....219K miles! Have you owned it the entire time? What is your mileage duration between oil changes? What oil do you use?
Racerbruce
