      07-25-2020, 09:44 AM   #1
LisaLannister
Drives: 2015 BMW 650 Xi
Rear springs need changing
The two rear springs on my Z4 need to be changed (cracked) and I am wondering if there other less expensive brands I can buy other than a dealer's OEM?
Thanks
      07-25-2020, 03:53 PM   #2
pungo
pungo's Avatar
I'd go for something like H&R sport springs on all 4 corners.
      07-25-2020, 05:09 PM   #3
kaybat
kaybat's Avatar
Drives: '06 Z4MR, '14 Cayman S
'06 Z4M  [0.00]
both sides? thats rare. Unless you're a suspension fanatic, I'd but some at a Jyard personally.
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
      07-26-2020, 09:55 AM   #4
TF07Z430i
Drives: 07 BMW Z4 3.0i roadster
It seems pretty common that bmw springs fail. I had 2 on my X3 rust and break. I replaced them with Bilstein springs. I think they were around $100 for the pair. You can buy used factory ones but they may not last.
wdb4718.00
      07-26-2020, 12:58 PM   #5
KevinC
your average JAMF
KevinC's Avatar
The factory springs were inadequately coated (probably just spray painted?). Most of the spring failures you see is in cold weather climates with salty roads. Out west it's almost unheard of.
If you have to replace a pair of springs, what about the shocks? Are they original? If so I'd definitely do all 4 springs & shocks/struts at once, as well as all related bushings/mounts (FCABs and RTABs for sure).
'21 M2 Comp
'19 Golf R
      07-26-2020, 03:23 PM   #6
wdb
dances with roads
wdb's Avatar
4718
I'm in a salty climate and the only spring I ever had fail on me was branded Prodrive (*wave* subiefolk). It had some kind of plasticky coating on the outside, which I imagine once it inevitably cracked, held the brine against the every-flexing steel spring, something which my very slight metallurgical knowledge tells me is a perfect storm for eating through steel.
      07-26-2020, 11:01 PM   #7
LisaLannister
Thanks for the responses. Very helpful.
Just thought I would make you all have a good laugh knowing that I googled Jyard springs only to realize a few minutes later that it was short for junkyard
kaybat125.50
      07-27-2020, 05:41 PM   #8
Huz-Z
Huz-Z's Avatar
That’s what us mechanical engineers refer to as a corrosion cell - crevice corrosion. The differential oxygen content of the water combined with dissolved corrosive agents like salt create a perfect storm for inflicting damage to metal. Nasty things for sure.
https://www.nace.org/resources/gener...vice-corrosion
      07-27-2020, 06:15 PM   #9
wdb
dances with roads
wdb's Avatar
4718
And then add torsion of the metal to the mix! I used to work for a specialty metals company that made drill collars, among many other things. They tested the material in a hot salt bath while applying torque.
      07-27-2020, 06:27 PM   #10
Huz-Z
Huz-Z's Avatar
Yup!!
https://www.nace.org/resources/gener...rosion-fatigue
https://www.nace.org/resources/gener...osion-cracking
https://www.sciencedirect.com/topics...g/stress-riser
      08-08-2020, 07:37 AM   #11
Mantraxalos
Drives: 2006 330i Manual
2007 Z4 3.0i  [0.00]
2006 330I  [0.00]
Thanks
I didn't want to lower my car or firm up the suspension at all due to the awful roads in MI.
I bought the German brand Suplex from ebay for about 180.00 plus tax for both of my rears. They work fine and raised the rear back up to stock height. They are for NON sports package Z4s.
After my research these were the closest to OEM non sports package coils that I could get and the price was right.
      08-10-2020, 06:10 AM   #12
Lucky1
Drives: '08 128i Coupe SGM 6MT
I see that brand come up a lot on this forum for these Zed's and Zee's. What is so special about them and what does it do to the car's ride and handling compared to OEM? Must admit I'm always skeptical of aftermarket suspension parts.
      08-10-2020, 11:50 AM   #13
rsutoratosu
Drives: Z4 3.0i
I'm interested in the same info, I can't lower the car anymore, bad nyc roads, is there HR that doesn't lower the car? I had H&R in my Acura TSX, I couldn't really tell if there were any difference
-Roranji
      08-10-2020, 10:41 PM   #14
pungo
pungo's Avatar
They offer sport springs that provide a mild lowering with a progressive spring rate that's not harsh yet firms up when pushed into turns therefore reducing body lean.
Not sure what model H&R springs you used on your Acura, some are close to stock. I believe the only H&R springs for the Z4 are sport springs (since it's a um, sport car) with mild lowering. Since you say your roads are bad, better stay with stock springs and not have better handling.
      08-11-2020, 09:07 AM   #15
maupineda
Drives: E86 Z4MC
The only H&R springs available for the Z4M are very aggressive, they lower the car an inch, and if you don’t want that low you are stuck. I have H&R coils and at their max height they are still lower than what I want.
kaybat125.50
      08-12-2020, 11:53 AM   #16
rsutoratosu
Drives: Z4 3.0i
I haven't driven the car in almost 2 months.. They're building new overpass and replacing bridges on I95.. roads have been cut up for repaving for months and still not done. It be waste of money putting it in and letting it sit till 2021.. I mean I can drive the car to go get milk but I don't need springs for that..
spring 2021 is when I can drive it
https://www.thruway.ny.gov/oursystem...staging-v7.pdf
-Roranji
      08-13-2020, 11:40 AM   #17
rsutoratosu
Drives: Z4 3.0i
Well, might as well prepare for future when roads are fix.. I forgot where I read it, better off getting coil over if you change to non factory springs ? I'm looking at KW v1s now. lol I saw bc racing coils comes with shorter end links, I assume I will need it for KW ?
-Roranji
      08-13-2020, 01:08 PM   #18
Mantraxalos
2007 Z4 3.0i  [0.00]
2006 330I  [0.00]
Both of mine were cracked at about 150k mi last summer. I noticed them both when I tried to change the diff fluid and the drain bolt could no longer be easily accessed since the ride height changed. They must have snapped while sitting over winter.
