04-19-2011, 06:47 PM | #23 | |
Rep 11,669
04-19-2011, 06:48 PM | #24 |
M = Midlife Crisis
66
Rep 2,006
Just loaded the car up! Your GC's have not arrived yet?
2006 Z4MC - #LL93158
04-19-2011, 06:58 PM | #25 | |
Rep 2,138
Drives: Me
My unofficial title is Geek. My official title is Submarine Combat Systems Electrical/Computer Engineer... which is way too long to say.. I normally use my unofficial title... |
04-19-2011, 07:41 PM | #26 | |
707
Rep 7,850
My unofficial title is Data Geek. I have a nice corporate title that includes Analytics and a bunch of other things in it, but I usually just go with my first name. I'm not a big fan of titles and prefer to look at what people produce/deliver and the means by which they do so (e.g. character). Man, less that two pages to take this thread off on some tangent! Meh, that's what I like about it here, lots of good info and some interesting discussion as well. |
05-01-2011, 07:27 AM | #27 |
Rep 11,669
We had our inaugural corner balance session yesterday with Caddyshks car.
It was a very interesting session that yielded some great results. Here is the 'before' data. (...not sure that we read the 'before' ride heights exactly) And the final data
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 05-01-2011 at 07:47 AM.. |
05-01-2011, 11:59 AM | #28 |
M = Midlife Crisis
66
Rep 2,006
05-01-2011, 02:44 PM | #29 |
Rep 1,603
Drives: Imola Red Z4MC
me next please
should i get an alignment done before or after we corner balance?
///M - Some Mods 'N Stuff
05-01-2011, 03:11 PM | #30 |
M = Midlife Crisis
66
Rep 2,006
After...
05-01-2011, 04:14 PM | #31 |
Rep 11,669
^WHS
Just get your ride heights where you want them. Then just ball park the camber & caster. Do you have your COs in already?
05-01-2011, 06:36 PM | #32 |
Rep 1,603
yep had em in for about a week so far but only actually drove her yesterday
05-03-2011, 01:10 PM | #33 |
Rep 170
Did you disconnect the swaybars when scaling the car?
Usually you need adjustable SB end links to proper scale/adjust the car. If not you end up loading up the swaybars. |
05-03-2011, 01:18 PM | #34 | |
Rep 11,669
Since they aren't adj. sways, are you better to leave them connected or not? (car sitting dead nuts level) When you hook 'em up again, won't you shift things? We'll probably end up with aftermarket sways & adj links eventually, but not this year. We're going to set the alignment then run it on the scales again. It will be interesting to see if the alignment shifts things at all.
05-03-2011, 01:36 PM | #35 |
Rep 170
I found alignment can have a noticeable affect on corner weights, it all
depends on how much the alignment is changed. (even tire pressures affect results - if you track you car you should set your tire pressures to your hot pressures) As for the SB - you need only one adjustable link in the front and back to properly set up your car. If not the car will not handle the same in left turns as in right turns. Having the car behaive the same way in both directions is the purpose of corner balancing your car with a 50/50 diagonal split. In short to do it right and get the benefits you really need to set your corner weights with the bars disconnected and then reconnect them and adjust the endlink til to achieve the same readings. Hope this helps... Last edited by BookerM3; 05-03-2011 at 02:20 PM.. |
05-03-2011, 02:07 PM | #36 |
Rep 11,669
Thanks for your help on this.
...there's nothing like experience.
05-03-2011, 09:43 PM | #37 |
Rep 1,603
PM replied
10-01-2011, 05:25 PM | #38 |
Rep 1,546
This died already?
Played with the scales lately? How were Vinnie's results? need moar! lol
10-01-2011, 06:18 PM | #39 |
Rep 11,669
Yeah, I use them every time I tweek the suspension.
Vinnie's car was MIA most of the summer, AFAIK it hasn't been done.
10-01-2011, 07:33 PM | #40 |
Rep 1,603
yep my car hadnt a chance at it yet, infact i still havent even gotten an alignment done yet lol
