07-24-2022, 09:48 AM | #1 |
Rep 232
Differential bushings - needs replacements
Sitting at 34K on my Z4M Roadster I started experiencing a clunk form behind when letting off the gas. I took it to a local shop where they are confirming that the front and rear bushings are completely toast. Are there only 2x I need to be changing or should I be looking out for any other components while I have the car up on the rack.
By the way, labor was quoted at $800.00 but Im looking around for a second quote. Is this the correct item that I am looking at https://www.turnermotorsport.com/p-3...l-bushing-set/
'06 Z4MR
Black sapphire / Imola |
07-24-2022, 03:44 PM | #2 |
Rep 778
There is a total of 5 rubber bushings on the diff carrier. In order to remove the diff carrier to change those bushings the exhaust system from the headers back has to be removed, then heat shield then reinforcement plate, then both tension rods, more heat shielding, then the driveshaft, then the side axles, then the diff carrier comes out.
With all that labour you would be wise to change every bushing that's in there.
2008 E86 M coupe
07-25-2022, 07:17 AM | #3 |
Not great. Not terrible
7441
Rep 2,700
And all that labor is why I just paid to have it done. I didn't want to try to do that on Jack stands.
1200 for all that. They replaced everything plus diff cover.
Current: 2024 BMW X3 M40i.
07-25-2022, 10:49 AM | #4 |
Rep 232
Im thinking the same thing, I just saw a YouTube Vid showing all that needs to come down in order to get to the diff bushings. I might as well change the CenterLine drive shaft bearing as well as the others ones noted above. I also plan to service the Dif with fresh oil.
'06 Z4MR
07-25-2022, 12:41 PM | #5 | |
7441
Rep 2,700
I do intend on refreshing the rest and putting in new shocks/struts this winter myself, but those all appear to be more doable on jack stands.
07-25-2022, 01:49 PM | #6 |
Rep 2,702
Albeit mine is a non M. But same operations.
My .02c is it's not that bad on jack stands with a couple of trolley jacks to lower the cradle sans rear diff and axles. There is a lot of stuff to remove before you get to point of removing the cradle however.
wdb4716.50 |
08-06-2022, 10:36 AM | #7 |
Rep 232
Excellent visual, much appreciated. We placed the car on a lift and saw where one of the cradle bushings was 75% gone with a bit of play, could be one of the main culprits for the clunk noise.
'06 Z4MR
08-06-2022, 01:42 PM | #8 | |
Rep 232
I have the rest of the rear carrier bushings all sort it out.
'06 Z4MR
08-06-2022, 04:00 PM | #9 | |
Rep 778
I haven't found them yet on realoem but they are sold.
2008 E86 M coupe
08-06-2022, 06:03 PM | #10 | |
Rep 2,702
Here is the info on the OEM rear bushings. Strange they recycled an old E36 bushing.
