      03-18-2021, 08:24 AM   #617
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
Vanne!
Wowie - do you have any data on the octane rating of the crappy fuel? Or, is the octane ok but it is the contaminants in the fuel that screw things up? It must be low octane otherwise you could install high-performing fuel filters to sort out the solids.
Racerbruce
Vanne1620.50
      03-19-2021, 12:13 AM   #618
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
well its the same as what you guys get over there. Ron .95 x98 = 93. so thats the ocatne rating.. which, unless your running low compression pistons (i am not) , will be an issue with 9 psi boost. Running Meth will up the octane rating to around 112 or 108 at the least, depending on the mixture. As an added bonus , it will also clean your intake and TB's/Valves/ etc.. so pretty much a win-win.. I guess the old engineers from WW2 knew a bit about engines.
There is a lot of stuff/muck in the fuel too though, and maybe yours is pre-filtered a bit better.
Powered by
      03-19-2021, 08:37 AM   #619
racerbruce
racerbruce's Avatar
3854
Well said -
There is a lot of stuff/muck in th fuel too though, and maybe yours is pre-filtered a bit better.
As any good sommelier would recommend, perhaps a high-octane, high-performing Cabernet will clean up the internals, provide additional power and when you push the "DRINK" button on your steering wheel, you'll receive the same!
Racerbruce
Vanne1620.50
wdb4732.00
      03-19-2021, 10:52 AM   #620
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
hahaha, thats gold.. ill take that advise to heart and act on it, starting tonight.
Powered by
racerbruce3853.50
      03-23-2021, 05:19 PM   #621
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
I spent most of my day off today refitting the oil coolers properly, as Initial placement had it rubbing the heat exchanger. Had to remove it any ways as it had a leak. (Go figure, brand new)
Other side. ...
Bonus ABS pump picture with custom braided lines.
And then things started looking up, my uprights arrived.. sadly though upon closer inspection, they need to go back and fixed, as they are slightly off.
New DSSR went in today.
wdb4732.00
      03-23-2021, 06:20 PM   #622
Steeler
Steeler's Avatar
2429
Epic build Vanne
Vanne1620.50
      03-25-2021, 10:54 AM   #623
F360C
Drives: E86 S54
Other side. ...
Attachment 2560443
Why did you have to switch to braided lines on the ABS pump?
07 Z4 M Coupe AW/IR
      03-29-2021, 09:40 PM   #624
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Good question...
As ive gone for a complete brake system from Wilwood, which included the removal of the brake booster, resiviours , and master cylinder, the Wilwood system is Imperial (que starwars music) and ofcourse the Bimmer stuff is all Metric. This wouldent have been an issue, however i need to keep the ABS unit, so had to make some custom lines from the new wilwood bias valve (allows me to change the brake bias front to back on the fly from within the drivers seat) to the ABS pump, which is what your looking at there... did they need to be braided? ofcourse not, i could have had them plumbed in solid lines, but for me this is much much easier. And yeah dont even start asking me about bubble and non bubble flares... lol..
Hope that made sense...
meanwhile... meth kit turned up, and drive shaft is back from the balancing shop. New DSSR is installed as are the new rear Toe adjusters.
Hopefully get some logs for Josh today...
Powered by
wdb4732.00
      03-30-2021, 09:30 AM   #625
racerbruce
racerbruce's Avatar
3854
Go Vanne....GO!!!!
This is an unreal build....this is well beyond just having the funds to create The Beast....its the skills required to create The Beast.
We are living vicariously through your pursuit - keep up the great work!
Racerbruce
pyshin110.50
Vanne1620.50
      04-13-2021, 07:56 AM   #626
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Decided to fix the uprights myself, sick of them just fucking it up..
Spent the day grinding (lol the alu...).
And Name:  23105E9A-83BC-4549-AAEE-05A9266C3942.jpeg
Next off to the paint shop for powder coating...
Powered by
wdb4732.00
      04-13-2021, 09:09 AM   #627
racerbruce
racerbruce's Avatar
3854
Greetings from Seattle -
They look great Vanne - well done; what is the back-story re those that fuc*ed up the process??
Racerbruce
Vanne1620.50
wdb4732.00
      04-13-2021, 09:29 AM   #628
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Greetings right back at ya from Dubai
The inserts that were cut out with water PSX machine, were offset by about 3mm’s from each other.. they couldn’t even figure out if they bolted them together than it would /have/ to be the same on each upright..
Powered by
wdb4732.00
racerbruce3853.50
      04-18-2021, 01:26 PM   #629
RvsBmw
RvsBmw's Avatar
13
Drives: BMW Z4 M Coupe
Great (and serious) build Vanne, following for a long time! Greetz from the Netherlands!
Vanne1620.50
      04-21-2021, 05:40 AM   #630
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Goeije dag then right back at ya!
Bit of wheel work.. I can't claim the credit, was completed by wheel paint shop..
Turned into this...
Fiat 750 marron Volcanio with 15 percent of A32 bmw.
Shit pictures.. but looks amazing.. (oh, if you use that, make sure to leave me some credit or paypal me a beer or 2
Powered by
inTgr8r2431.50
racerbruce3853.50
pyshin110.50
      04-22-2021, 04:19 AM   #631
Memento1731
Memento1731's Avatar
Netherlands
49
Drives: Z4M Coupe
Nice wheels. Is that a dark bronze color?
Alpine white/Imola red, G-Power SK1 kit 416 whp, 200 cell cats, Supersprint Race cans, Fortune 500 coilovers, 19" Z Performance ZP2.1 Wheels, Vibra-technics Engine mounts, Rogue transmission mounts, Rogue RTAB, Tekarbon CF trunk spoiler, Carbon roof Geoff Steel, OE ZHP short shift knob, CDV delete, stubby antenna
      04-22-2021, 04:35 AM   #632
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Afirm sir!
      04-22-2021, 04:53 AM   #633
RvsBmw
RvsBmw's Avatar
13
Haha, thanks. In my mind i saw a post that you have/visited a family member in Holland .
Looks great! What sizes are those rims (J)?
      04-22-2021, 07:29 AM   #634
racerbruce
racerbruce's Avatar
3854
Well done Vanne!
What color have you chosen for the body??
It seems that the rim colors will compliment most any body color, for sure.
Racerbruce
      04-22-2021, 08:53 AM   #635
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Sizes are 10" and 11.5" can't remember offsets by heart.
      04-23-2021, 06:54 AM   #636
F360C
Drives: E86 S54
Oh wow! Who makes those?
07 Z4 M Coupe AW/IR
      04-23-2021, 12:16 PM   #637
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Sportline. Flow formed, pretty light, and good quality..
      04-26-2021, 02:40 AM   #638
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Originally Posted by racerbruce View Post
Well done Vanne!
Haven't selleded on a color for the body yet... Will probably stay multi colored for the initial 2 shake down runs.
