01-21-2019, 01:50 PM | #45 |
Rep 4,210
I was listening to an older click and clack podcast today while exercising and they addressed this very question.
If it is well below zero, they recommend a 30 second to one minute warmup but no longer. Above that, they recommend no warm up but drive a couple of minutes on local roads if it is very cold before jumping on a high speed motorway. |
01-21-2019, 04:02 PM | #46 |
Hoonigan
6843
Rep 3,000
Drives: '09 328i, '98 Wrangler
Cars warm up faster driving them lightly for a mile than just sitting there idling. That said I will only warm mine up for a few minutes if it's super cold. For me not for the car.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
01-21-2019, 04:30 PM | #47 |
Rep 1,003
Drives: 2008 BMW 135i (E88 N54 6AT)
I follow the advice of this article:
https://www.msn.com/en-us/autos/owne...ter/ar-BBQdbev Basically, I let it idle for 30 seconds to 1 minute, then drive gently until the JB4 flashes the blinkers at me, telling me the oil's up to temperature. |
01-21-2019, 06:22 PM | #48 |
Rep 96
Wait for cold start to drop the RPMs and go. I’ve owned a lot of cars and never really cared about warming it up UNLESS it was really, really cold. Seems to be working for me.
01-21-2019, 07:19 PM | #49 |
Rep 888
Drives: 2019 M550i
No, location of the turbos on the V8 warms up the block pretty quickly. Think I get a mile or two and its up to operating temps.
01-21-2019, 08:21 PM | #50 | |
Rep 620
Drives: E90 335XI MSport, S2000
Soterios575.00 |
01-21-2019, 10:17 PM | #51 |
Rep 18
Drives: F80 M3
I tend to start the car right as I get in, then get myself situated while the engine is running. Pulling out of where ever I'm parked and the first few miles I take it easy on the car. Especially in these single digit temps were seeing in the northeast these past few days. It's not only because of engine oil temp, but also being gradual on everything else.
01-21-2019, 10:31 PM | #52 |
Rep 2,476
I've actually timed both, and found that it(2010 335i w/oil cooler) does not warm up faster while driving. It actually takes right about the same amount of time. With that said, I'll continue to let my car idle until the oil temp gauge starts to move before driving off. At the bare minimum, and if I'm in a hurry, I wait until the oil level sensor reports all is good, which takes a minute or two.
Wolf 3352340.50 |
01-22-2019, 05:45 AM | #54 |
Rep 2,672
I keep the door open, start the car and listen for a few secs to make sure she is rumbling properly and there are no unusual sounds while I'm turning on buttons and getting ready, and then close the door and go. As I am pulling out of garage I look in front on the floor to make sure there are no fluids. The first 2-3 mi easy riding and shifting at 3k.
01-22-2019, 07:33 AM | #55 |
Rep 466
Start the car. Glock from the belt to the cup holder, seatbelt, radio, nav, check gauges, look in mirror, then drive. Take it easy out of subdivision and easy to the main road.
Now, my buddy, has a work car- Dodge Charger. On a cold day he starts it up and right into drive. If the windows are frosted he will drive at high idle using the brakes. 0-60k miles without issues. If windows are not frosted its full throttle right out of the driveway. Lots of people live near major roads that require them to quickly accelerate and merge into traffic. Does it decrease the lifespan? Maybe instead of lasting 400k miles it will only last 350k miles. |
01-22-2019, 11:04 AM | #56 |
Retired BMW Genius
2897
Rep 3,404
Nope. I give it about 15-20 seconds for the revs to settle and drive off.
01-22-2019, 10:53 PM | #57 |
David
786
Rep 2,009
Seems like nobody here commenting has talked about diesels..
My diesel starts up at idle speed, rougly 700rpms i'd guess. Oil temp takes literally 30 minutes to reach center (210F) here in California mornings, 50-60 degrees, and that's 30 minutes of driving at highway speeds, not idle. Idling would probably take an hour.
01-23-2019, 01:34 AM | #58 |
Rep 1,003
Yeah, I have to warm the glow plugs on my diesel for about 30 seconds before even trying to turn it over.
I don't specifically warm it up, but it takes a while to get the slasher attached to the PTO - so I'd say it gets about 10 minutes to warm up before doing any real work. (EDIT: I respect all y'all maturity for not taking the bait; but I'm really disappointed that nobody called me out on the fact that you'd rip your arm off if you tried to connect a slasher to a power take off while the tractor was idling. Did none of you grow up on farms??) Last edited by xQx; 02-13-2023 at 09:15 PM.. |
01-23-2019, 06:43 PM | #59 |
He's experimenting with something...
335
Rep 261
I think the winding noise you hear is normal as the sychomesh works to prepare for the shift. A mechanical engineer could explain that much better than I. My issue is a horrible if brief grinding, first to second, if I shift quickly when the car is cold. If I shift slowly, no grinding when cold and no grinding ever once the car is properly warmed up.
Analog 2011 e92 M3 | Jerez Black | Black Novillo | 6MT | CF roof | No iDrive, Nav, M button, ZCP, EDC, or center hump | ZHP shift knob | OMP 1010 pedals | K&N filter | Dinan engine tune | OEM exhaust mod (bypass) | EAS exhaust tips | shaved front bumper | 19" Apex EC-7 | 12 mm rear spacers
01-23-2019, 07:11 PM | #60 | |
Rep 6,290
Damn that sucks though that you hear grinding, usually grinding isn't super great but at least if you shift slowly you don't hear it that's good! |
01-28-2019, 03:44 PM | #62 |
Rep 937
I think what people get confused about is the manual says theres no need to "warm up" which means the oil is up to temperature or even till the needle starts moving!
That'll take 10+ minutes if the car is just sitting still. So i think that's what the manual is suggesting NOT to do.... It's fine to sit for a couple of minutes until the revs drop or until you're ready to go ALSO they dont want people to think "car is warmed up sitting in the drive way! so I can drive aggressively!"
Hi
01-28-2019, 04:29 PM | #63 | ||
Rep 15,858
I do wonder how many BMW engines which burn excessive oil, have idle/stationary warm ups, which can contribute to the problem. |
01-28-2019, 05:27 PM | #65 | |
Rep 15,858
My own car, the first couple of changes can be less smooth, if I don't allow a few extra seconds before moving off, when the temperature is low, (~0C). I have the benefit of driving up a lane for about 1/4 mile before the highway. The gearbox is silky smooth by the time I pull onto the highway, even at low winter temperatures. |
01-28-2019, 06:32 PM | #66 | |
Rep 937
Let me know how unambiguous that is by telling me what temperature "warm up" is
Hi
