07-29-2013, 08:28 PM | #1 |
Rep 396
Holding the lock/bmw roundel
I'm curious regarding this ...(not sure if it was holding the lock button or the trunk button)... i will have to double check
When the car is locked, on my inside rear view mirror, a light flashes every 4-5 seconds... Once i hold the lock button (or maybe the trunk button) for about 5 seconds... the red light on the inside starts going at about every 2 seconds.... what does this do? |
07-29-2013, 09:17 PM | #3 |
Rep 224
Surely he must if he has the blinking light.
Maybe its a force override to turn on all security features. I know someone mentioned recently their car had an alarm but the tilt sensor and motion detector wasnt activated. Maybe doing this turns those on and it blinks faster to signal the alarm is in a more alert mode. Really just making stuff up. I have no idea. |
07-29-2013, 09:23 PM | #4 | |
Clueless
Rep 116
07-29-2013, 10:56 PM | #5 |
Rep 396
I just got the car a few days ago...
The car doesn't have any remote for an alarm though... I just have 2 bmw regular keys with 3 buttons! ... weird? |
07-29-2013, 11:14 PM | #6 | |
Rep 224
Panic button is the only thing that would be missing without a traditional alarm fob (since the unlock/lock is on the key), and you can turn on panic mode by holding down the lock button and the trunk unlock button together for a few seconds. |
07-29-2013, 11:44 PM | #7 |
1654
Rep 4,318
Really? I had no idea about the panic mode.. Will have to try that...
Also anyone know if there is a sensitivity adjuster for the alarm? (Not meaning to hijack the thread btw
Powered by |
07-30-2013, 12:36 AM | #8 |
639
Rep 3,124
I was tempted to try some things, but then decided it was best not to chance setting off my alarm at 10:00 PM.
Maybe I'll try tomorrow. But I did stumble across this, while looking at 1-touch modules: Gap-Tech says: "Because you are not clicking twice on the lock button your interior movement or tilt sensors will not get disabled as will occur with other remote modules." Do we even have an interior movement sensor? I tried leaning into the car and waving my arms around once with the top down and alarm set, and nothing. I did discover that opening the center storage compartment will set the alarm off (Storage compartment lock disabled by previous owner. I decided to leave well enough alone. At least it alarms.)
07-30-2013, 05:15 PM | #11 |
Rep 2,650
Drives: Z4MC, X3-35i,525i, Corrado G60
The below works properly if the coding was done to enable all the functions. Many installations do not have the interior motion sensor since it cost more. The below is from the manual of a 2007.
Alarm system* The concept The vehicle alarm system responds: > When a door, the hood or the luggage compartment lid/tailgate is opened > When attempts are made to start the vehicle > When there are movements in the vehicle interior: interior motion sensor, refer to page 24 > When the car's inclination changes, for instance if an attempt is made to jack it up and steal the wheels or to raise it prior to towing away: Tilt alarm sensor, refer to page 24 > When there is an interruption in the power supply from the battery The alarm system signals unauthorized entry attempts for a short time by means of: > An acoustic alarm > Switching on the hazard warning flashers > Flashing the high beams Arming and disarming When you lock or unlock the vehicle, either with the remote control or at the door lock, the alarm system is armed or disarmed at the same time. The hazard warning flashers light up once when the alarm system has been properly armed. You can have different acknowledgment signals set to confirm arming and disarming.< Even when the alarm system is armed, you can open the luggage compartment lid/tailgate using the button on the remote control, refer to page 19. When you subsequently close the luggage compartment lid/tailgate, it is locked again and monitored. Switching off an alarm > Unlock the car with the remote control, refer to page 19. > Turn the master key in the ignition lock to position 1, refer to page 40. Indicator lamp displays > The indicator lamp beneath the interior mirror flashes continuously: The system is armed. > The indicator lamp flashes immediately after the vehicle is locked: Doors, hood or luggage compartment lid/ tailgate are not properly closed. Even if you do not close the alerted area, the system begins to monitor the remaining areas, and the indicator lamp flashes continuously after approx. 10 seconds. However, the interior motion sensor is not activated. > If the indicator lamp goes out immediately after the vehicle is unlocked: Your vehicle has not been disturbed while you were away. > If the indicator lamp flashes for 10 seconds immediately after the vehicle is unlocked: Your vehicle has been disturbed while you were away. After an alarm has been triggered, the indicator lamp will flash continuously. Tilt alarm sensor The inclination of the vehicle is monitored. The alarm system reacts e.g. to attempts to steal a wheel or tow the vehicle. Interior motion sensor* Coupe All windows must be closed in order for the interior motion sensor to function optimally. Roadster The system monitors the footwells and the seating areas of the driver and passenger. Even when the convertible top is open, the alarm system including the interior motion sensor is armed. Objects falling into the vehicle, e.g. leaves, can trigger unintentional alarms, refer to Avoiding unintentional alarms. Avoiding unintentional alarms The tilt alarm sensor and interior motion sensor can be deactivated at the same time. In this way you can avoid unintentional alarms, e.g. in the following situations: > In duplex garages > When transporting the vehicle on car-carrying trains, by ship or on a trailer > When animals are to remain in the vehicle Switching off tilt alarm sensor and interior motion sensor > Press the button on the remote control twice in a row. The indicator lamp lights up briefly and then flashes continuously. The tilt alarm sensor and the interior motion sensor are deactivated until the vehicle is again unlocked and locked. |
07-30-2013, 07:58 PM | #13 |
Rep 231
I don't have an alarm, but mine does the same thing as OP...its just a deterrent if you don't actually have the alarm installed, or you may have it installed but not activated by the dealership but I doubt one would have it installed and not have it activated but its possible
07-30-2013, 10:46 PM | #14 |
639
Rep 3,124
Pressed the lock button twice fast and now it's flashing once every 2 seconds.
Or did it always flash once every 2 seconds? Now I can't remember! I disabled my tilt sensor with Progman long ago, because the driveway's pretty steep and I'm in earthquake land, so maybe it's always been in that mode. Or I just double-secret-disabled the tilt sensor and I just don't know how to get in back to "normal".
08-02-2013, 06:14 AM | #15 |
Rep 704
Drives: '08 MC
OP - Its generally a way to turn off the motion sensor that Pungo mentioned in his list above. I pull this move all the time in the wifes X3 when we leave our dog in the car for a few minutes (with windows ajar of course) but want to lock the car. This way the dog doesnt set off the alarm and also make himself deaf at the same time.
The motion sensor and subsequent interior alarm that my 540 has is so sensetive and loud, its designed to actually disorient any potential intruders. 'eardrum pearcing' is an understatement. Anyone wanting to test thiers... be ready for it!
08-02-2013, 08:19 PM | #17 | |
Rep 231
08-03-2013, 10:38 AM | #18 | |
Rep 704
Drives: '08 MC
Sorry don't mean to thread jack.
