      03-14-2019, 01:25 PM   #45
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Appreciate all the info in this thread and just sharing some measurements and total weight figures from my recent corner balance.
~11 Gallons of Gas (nearly full) and No Driver: 3,141lbs
FL:823 | FR:822 | RL:856 | RR:790
----Corner Weights include a 150lbs driver----
F/R Weight: 49.99%
Cross Weight: 49%
Major Weight Reduction Performed to Z4M Coupe w/ Nav & Premium Package:
- Braille 15Lb Battery: -33lbs
- Removed both Subwoofers: -16lbs
- Hatch Plastic, Theft Cover, Lining & Tool Kit: -40lbs
- Delete: AC Compressor/Condenser/Lines, EGR, Washer Fluid Tank: 51lbs
- Race Seats w/ Brackets: -64lbs
- Cat-less Headers: -10lbs
- Rogue Exhaust & X-Pipe: -19lbs
- Bolt-In Roll Bar & Fire Hydrant: +43lbs
- APR GTC200 & Splitter: +15lbs
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red |
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage
Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo
Mirko182.00
Vanne1620.50
kaybat125.50
      03-15-2019, 07:55 AM   #46
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
mine for reference Azeka,
That's with rollbar, rear and front Stb (back one is heavy) big battery in the boot, (11lbs one on the way) and door cards in place. Lol and full fuel. so half tank would be minus 20 kgs or so.
if I take -33 lbs for the huge batt for brallie swap out.. (I also have the 15lbs one) installed a week or 2 ago.
33/2.2= -15kgs.. would bring mine to 1376 kgs.. that's 3027 lbs.
Intrested in how you installed the new batt, I umed and arred a long time before finally placing the new batt and its holder.
i /did/ however pull the whole radio/nav thing bit out though..
Powered by
Azeka1285.50
      03-15-2019, 08:50 AM   #47
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Thanks for sharing, Vanne! We have very similar mods so this is a good comparison. Interesting how with your heavy battery you are still 90lbs lighter I guess the Radio/Nav/Amps all add up...
As a point of clarification, my corner weights include a 150lb ballast for driver (Will update my post).
With regards to the Braille Battery, I used a Macht Schnell mount for E92, fits perfectly.
Vanne1620.50
      03-15-2019, 09:27 AM   #48
dre99gsx
Drives: 1994 Toyota Supra
For reference:
My z4 non-M coupe
3160lb
fulltank gas
1gal water/meth in rear
52.3% front
47.6% rear
9lb braile in rear
2jz up front
no cage, race seats
all amenities (AC, lcd-screen nav/radio, speakers, heavy wood-grain dash panels)
every time I reduce weight, seems to be from the rear. There is more I can remove, but I don't want to make the front/rear balance worse.
Planning a cage soon, 40lb more to the rear I guess.
Azeka1285.50
      05-04-2019, 04:05 PM   #49
MC007
07Mcoupe
Drives: Bmw Z4Mcoupe
Anyone do cf hoods.
      06-16-2019, 09:42 PM   #50
dre99gsx
Anyone have the weights of their dash panels? Looking for wood, aluminum and carbon variants to add here.
      06-22-2019, 07:04 PM   #51
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
See post #28.
      06-22-2019, 07:05 PM   #52
Michael9218
595
Originally Posted by MC007 View Post
Anyone do cf hoods.
The M's have an aluminum hood that is pretty light. Little bang for the buck in a CF hood.
      11-14-2019, 04:43 PM   #53
dre99gsx
Can anyone supply weights for:
AC Components
      11-14-2019, 06:28 PM   #54
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
See Post 45
AC Components
Racerbruce
Vanne1620.50
      11-19-2019, 09:55 PM   #55
Calichase
Drives: '07 s/c'd Z4MC '08 e82 '02 m3
Adding another data point. Some of you may find this interesting as I'm supercharged
Z4m coupe
3/4 tank
A few mods that probably effect weight
Recaros and fixed seats
Euro headers, catless section 1, with RPIs
Arc8s (18x10s)
Ltw 12lb battery
Vf570 (or what started out as that)
Dual 25 row oil coolers (replaced oem) (+1.5L oil)
Massive 2.5 gal ATW heat exchanger (3x bigger then oem vf) (+35lbs hanging off the front of the car when filled)
3241lbs with driver (185lbs). Definitely need to corner balance, but playing with tire sizes and waiting for an alignment first. Honestly thought I'd be closer to 3300 with the blower and auxiliary supporting mods.
What amazes me is our little cars are pretty damn heavy compared to larger body vehicles (my stock ish e46 m3 for instance is 3450 with me in it, and I can more easily take out 350lbs if I went full race mode, where as removing weight gets asymptotically difficult in our cars due to the size). I guess that's what we pay for with the chassis torsional rigidity.
Vanne1620.50
      12-04-2019, 04:31 AM   #56
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Couple more bits..
"Press to retract mirrors" 1.5kgs each.. that's a lot..
6.6lbs for both.
Replaced with GT2 race mirrors.
      12-04-2019, 02:18 PM   #57
racerbruce
racerbruce's Avatar
3854
Well done Vanne!
What do the new GT2 mirrors weigh??
Removing 6.6 lbs (minus the replacement mirrors) from the upper area of the vehicle has a very positive effect on the center of gravity (CG).
Racerbruce
      12-04-2019, 02:27 PM   #58
racerbruce
racerbruce's Avatar
3854
Wowie Calichase -
3,230 lbs stock
3,056 lbs w/o driver
Weight reduction: 174 lbs
That's a big deal!
Racerbruce
      12-05-2019, 11:24 AM   #59
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Originally Posted by racerbruce View Post
Well done Vanne!
About 500 grams for both.
      12-05-2019, 05:20 PM   #60
racerbruce
racerbruce's Avatar
3854
Wowie!
500 grams = 1.1 lbs
6.6 minus 1.1 = a 5.5 lbs savings....that's considerable based upon the location of the weight!
Racerbruce
      12-06-2019, 01:39 PM   #61
Michael9218
595
Mine with @7 gallons and driver weight. About 2,670 empty.
Vanne1620.50
      12-06-2019, 10:33 PM   #62
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
thats pretty light mate, mind adding the things youve added/removed from the car?
Powered by
      12-06-2019, 10:37 PM   #63
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
guys, whats required for the ac/heater removal?
Powered by
      12-07-2019, 07:06 AM   #64
Michael9218
595
I think it’s easier to just refer you to my build thread...
      12-07-2019, 07:10 AM   #65
Michael9218
595
Since you’ve already removed the dash, just remove the dash bar and pull the lump out. In the engine bay, just remove the components. You will need to plug the aluminum tube that feeds the heater core and also plug the steel return tube. I removed them and had a local shop TIG weld caps. I made a small aluminum plate to block the holes in the firewall.
      08-23-2020, 12:38 PM   #66
rueyme
Drives: red z4
Do you have pics of the gr2 mirrors on your car?
