      10-14-2019, 02:07 PM   #1
eggman51
Sway Bar mount point reinformcement ?
I am planning a coilover suspension upgrade for my 2006 BMW Z4M Roadster. I will likely do this in the coming Spring 2020 if all goes to plan.
The trustworthy and reputable shop I am doing the work with suggests I consider a front sway bar upgrade to a medium stiffness Ground Control sway bar.
Somewhere on these forums I came across a post about re-enforcing the front sway bar mount points as the extra stress from aftermarket sway bars can rip out the original mount points. I can't find it now!
Does anyone have any info on reinfomrcing the front sway bar mounts?
Do you really need aftermarket sway bars on these cars?
Would swapping out the rear sway bar at the same time make sense?
Any reinforcement required for the rear sway bar if it was swapped out?
Thansk!
Eamonn aka eggman
      10-14-2019, 02:13 PM   #2
Steeler
Steeler's Avatar
2429
Thansk!
Eamonn aka eggman
https://www.zpost.com/forums/showthr...ht=Reinforcing
      10-14-2019, 02:23 PM   #3
eggman51
Thank you so much... sway bar vs anti-roll bar, should have kept adjusting my search; much appreciated.
      10-14-2019, 08:03 PM   #4
jmillet
jmillet's Avatar
64
FORGET ARB
If you're planning on installing coil over suspension with linear springs like the TC Kline set up then you don't need different ARBs. You didn't indicate why you're going with a coil over suspension. If you don't plan on doing driving school HPDE events then you don't need to spend the money on coil overs. My Z4MC spends most of its time on the track so coil overs and camber plates make sense.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      10-14-2019, 10:21 PM   #5
eggman51
Hi Jim,
Good to know about the anti-roll bars and coil over upgrades. While the car is my daily driver, I did about 10 track days this year (my first year owning it), and plan to do at least that many next year.
I want to go with a 275/35/18 squared setup as well as address what feels like pretty beat up shock absorbers, so I am planning to do a 2 way remote reservoir MCS coilover upgrade.
I was debating MCS or JRZ, but there is a shop that provides great "at the track" service who specialize in MCS, so I am going to go that route.
Cheers,
Eamonn
      10-16-2019, 10:56 PM   #6
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Hit Lev up for as set of re-inforcement plates.
Powered by
      10-17-2019, 12:08 AM   #7
eggman51
Yep.. pinged him and he's either got some around or will make some in the near future.
      11-04-2019, 09:44 PM   #8
thrak410
Drives: 2004 Z4 Roadster
Who is Lev? I’d like to get a set too.
      11-15-2019, 08:12 AM   #9
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Originally Posted by thrak410 View Post
Who is Lev? I'd like to get a set too.
I have stainless plate laying around and made a pair off of a diagram that was posted....haven't gotten around to test fitting them but the are definitely within the ball park...if you don't get a response or don't mind tweaking them if need be I can throw a set together this weekend
      11-15-2019, 08:17 AM   #10
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
These are the ones I made
3002 tii2281.50
      11-25-2019, 09:09 AM   #11
thrak410
I was able to make my own this weekend, thanks!
The difficulty I ran into was my mounting bolts were offset, and then the 'curve' of the transition in the frame.
3002 tii2281.50
WickedNy225.00
