10-23-2020, 03:42 PM | #1 |
Admiral
240
Rep 314
FS: REVSHIFT Performance Flex Disk (Guibo Disk)
REVSHIFT PERFORMANCE ENGINEERING BMW Race Flex Disc - (LK=96mm/12mm) List Price is $129.99; On sale for $100.00 Absolutely New in Original Factory Packaging Shipping to continental USA is included. From the manufacturer: The Revshift race flex disc frame is made from 6061 aluminum with type III hard anodizing and utilizes high quality polyurethane bushings to maximize stiffness and strength while maintaining an appropriate amount of flex. FOR RACE USE ONLY! This part is very rigid and requires precise installation. The driveline must be properly aligned and all driveline components must be in good condition and properly balanced. The engine mounts, trans mounts, differential bushings, and subframe bushings must all be rigid to prevent driveline movement. We recommend a hardness of 95a or higher for these components. A new center support bearing and driveshaft centering bushing are also recommended. Features: - 6061 aluminum frame with type III hard anodizing - 95A polyurethane bushings - Replaces OEM part # 26117511454 and part # 26112226527 (LK=96mm/12mm) - Rebuildable using one of our flex disk rebuild kits |
