11-15-2020, 09:08 PM | #1 |
Rep 239
All these lights came on in the dash, please help!
Hi,
Today in my E85 2007 without any reason all these lights come on. In my mini cooper the reason is one speed sensor damaged, in a Z4 E85 its the same? Please help me! Last edited by mariocaz; 11-16-2020 at 10:11 AM.. |
11-16-2020, 11:16 AM | #3 |
Rep 208
Drives: 08 Z4 M Coupe
I would start with the battery and alternator. If they're ok, then you're probably looking at a DSC module failure. You can get rebuilt ones from Module Masters for a much better price than direct from BMW.
11-16-2020, 04:57 PM | #4 |
Rep 239
I already scanned it and the code is Steerinf angle sensor.
The aligment of my steering wheel is so bad because I just replaced the lower control arms, the bushings and other parts there too, my steering wheel is not aligned at all and I will leave the car this week to do the aligment service, do u think this is causing the problem ? and with the aligment to the wheels and erase the code with the scanner could fox the problem ? |
11-16-2020, 06:03 PM | #5 | |
Rep 279
11-16-2020, 06:09 PM | #6 | |
Rep 239
So I mean the other lights / codes, I scanned the car and the code is Steering Angle sensor. |
11-16-2020, 07:32 PM | #7 |
Rep 208
Based on what you've told us so far, I would troubleshoot in the following order:
Put air in the tires Get an alignment Check battery and replace if needed Check alternator and replace if needed DSC unit Is there anything else on the car that was changed recently?
11-16-2020, 08:02 PM | #8 |
Rep 2,546
Put the vehicle upright, they complain when they're on their side
Assuming you verified the battery is healthy, disconnect batt for an hour, reconnect and see if the lights come back on. |
