07-18-2013, 10:47 PM | #1 |
Rep 83
235/265 Michelin PSS + stock setup
Hi All,
I need some help from all you wheel / suspension gurus. I've been doing some extensive research to replace my stock OEM tires. Everything on the car is stock suspension and wheel wise. I'm looking to purchase a set of Michelin pilot super sport tires for improved handling and grip. The car will be 80% street use and 20% track and autox. What do you guys think about the following tire size? Would I need any adjustments or mods to make them fit? Front: PSS 235/40/18 Back: PSS 265/35/18 Any tips and guidance will be greatly appreciated, thanks! |
07-18-2013, 11:34 PM | #3 |
636
Rep 3,124
I understand this has been done on stock wheels and suspension with no rubs:
Front: PSS 245/40/18 Back: PSS 275/35/18 What I plan to run on my next set, so you should have margin. |
07-19-2013, 09:29 AM | #7 | |
Rep 69
Front: 235/45/18 Rear: 265/40/18 This setup fits fine and, compared to the one you mentioned, it has two main advantages: - the overall wheel diameter is closer to the original one, and actually improves speedometer precision; - the sidewall is just a tad higher than original, which offers better rim protection. |
07-19-2013, 11:49 AM | #8 | |
Rep 83
07-19-2013, 12:00 PM | #9 |
Rep 4,531
235/265 is ideal for OEM widths.
Going 245/275 isn't recommended by me because it will result in tire shimmy on the wheel, which will reduce overall grip and response of the tire. I run 235/45 and 265/40 |
07-19-2013, 12:44 PM | #10 |
Rep 1,135
07-19-2013, 01:34 PM | #11 |
Rep 4,531
You're fitting too much tire on a limited width wheel.
Can you fit 245s on the wheel? Of course. Is it beneficial? Nope. There comes the law of diminishing returns when it comes to tire size on a confined wheel width. 245 is that limit. When you get a tire on a wheel that much, the tire actually moves back and forth on the wheel before the sidewall deflects and you get your grip. From the time the tire moves, to when the sidewall actually deflects takes away response and actual corner grip from the wheel. This is why you don't see many people squeezing street tires as big as they can onto a wheel when it comes to competition. They can probably go +20mm bigger, but it isn't ideal. For example, on a 9.5" wheel I'd go 265mm. Even though you could go up to 285mm most likely, stretching the sidewall a bit to make it stiffer increases response and feel through the wheel. Now, when you get to R-Comps...this is a different story. And when you're really pushing the tire, this is what deflection looks like: |
07-19-2013, 02:49 PM | #12 |
Rep 400
Man, this is a timely thread! I'm planning on the same PSS setup and was wondering what other people think. I was wondering about 235/40 or 235/45 and 265/35 or 265/40.
What are the advantages of going with 235/40 and 265/35? I'm looking to purchase in the next few weeks. |
07-19-2013, 03:15 PM | #13 |
707
235/40 and 265/35 provide a bit more wheel torque (smaller diameter), a bit more sidewall stiffness, and a small bit of ride penalty (but with the softer PSS sidewall, it's largely negated vs. say a very stiff sidewall tire).
BTW, the right sizes are 235/40 (not 45) and 265/35. I really like this combo on stock wheels. A lot! Kgolf's explanation is on the money. On the track, I tried running the 245/275 combo on stock wheels. Despite attempts to adjust tire pressure, the center of the tire was consistently 20 degrees or so hotter than the inside or outside edges. That means all that nice extra rubber I bought was going to waste. Traction was horrible, as essentially the middle not the whole tire was providing the contact patch. (A really stiff and square tire, like the old Star Spec, might do better, but I have no data.) Basically it's stuffing too much tire on the wheel. It fits, but if the point is better performance, it doesn't provide it. We put those same tires on an 8.5/9.5" wheel set and the difference is night and day. |
08-12-2013, 03:15 PM | #15 |
Rep 13
Having now more than one year return of experience on Michelin PSS 19" 235/35 in the front and 265/30 in the rear....I can just encourage you to go for this set which provides a great handling and precision on track.
Don't know how far your size in 18" will make a lot of difference....
Z4MC / ZR CDV / G-Power exhaust / RE X-Pipe / GruppeM / NGK Irridium plugs / Sport System ECU / RE RTABs & RSMs / Bilstein B12 / VMR VB3 Michelin PSS / M Strut / AP Racing 6x4
08-20-2013, 09:09 PM | #16 |
Rep 83
Thanks for the valuable feedback guys! I ended up going with the 235/40 and 265/35 setup and it handles like a dream! Now the car feels more alive and ready to pounce, I'm completely satisfied! I haven't gotten the chance to push them hard to the limit yet, but the grip is noticeably improved from what I've experienced so far.
08-20-2013, 10:00 PM | #17 | |
707
08-20-2013, 10:08 PM | #18 |
Rep 2,138
Drives: Me
With the setup in the original post (Front: 235/40/18 - Back: 265/35/18) on stock wheels, you can also put a 10mm spacer in the rear with no issues.
08-22-2013, 09:31 PM | #19 |
Rep 251
08-22-2013, 10:08 PM | #20 |
Rep 2,138
Drives: Me
I put a spacer in the rear to widen the track for straight line braking stability. I put a spacer on the front for handling. Pushing the fronts out makes the car rotate more/reduces understeer. On shorter tracks, slower tracks, I remove the rear spacers.
Of course widening the rear reduces the effect you get when you widen the front. Everything is a trade off... I learned of this from James Clay of Bimmerworld. I am contemplating a new set of wheels, going from a 8" to 8.5 (fronts), with an ET of 35 all around. This will push the front wheel out 13mm from stock. |
10-14-2014, 05:46 PM | #21 |
Rep 1
Has anyone run 235/45 fronts and 265/40 rears on stock Z4M OEM wheels (18's with 8" fronts and 9" rears)? I am looking for a little more sidewall height to protect alloy rims from Virginia pot holes (my technician recommended this), and I want to make sure there are NO rub issues before I order them. I can't afford the expense right now or new rims, so that option is off the table. Thanks
Yesterday at 1:14pm · Like |
