08-27-2019, 07:24 PM | #1 |
Rep 12,565
Weird Steering Wheel Vibration at Freeway Speeds
Can’t diagnose the issue but shimmy occurs only at freeway speeds ( > 65 mph)
- 50,000 miles with no accident history - No spacers installed - Wheels and tires balanced - Rotors and pads - Wheel spins freely on jacks (i.e. not stuck caliper) - Control arm and bushings replaced - Alignment checks out (camber is even and adjusting toe had no impact) Anyone got ideas on what’s causing this? Did a suspension refresh last year when I first picked it up. Only original suspension components remaining are tie rods and end links but can’t see how those pieces would contribute to this kind of vibration. Edit - see post 24 for resolution Last edited by 3002 tii; 11-04-2019 at 07:35 PM.. |
08-27-2019, 08:38 PM | #3 | |
Rep 12,565
No side to side play to suggest bearings are worn. Plus no audible whirring noises or the sort. Last edited by 3002 tii; 08-29-2019 at 07:12 AM.. |
08-28-2019, 06:54 AM | #4 | |
Rep 108
Drives: 2004 BMW Z4 3.0I
Does the vibration increase with speed? If so, it must be balance Or TPM sensor. It does look severe. |
08-28-2019, 08:07 AM | #5 |
Rep 1,966
Probably not the issue but I'll throw it out there as I used to notice a really weird vibration driving on a particular highway near my home. I eventually realized it was the road surface and not the car but it took me a while to figure out that it wasn't the car but the uneven road surface.
08-28-2019, 08:13 AM | #6 | ||
Rep 12,565
I immediately thought of this old thread and wondered if this is what others were going through... https://www.zpost.com/forums/showthread.php?t=855939 Quote:
08-28-2019, 11:52 AM | #8 |
Rep 2,864
Hub centric
08-28-2019, 12:27 PM | #9 | |
Rep 1,373
I had the same sort of vibration... came and went while driving. It also seemed to increase with speed. Ended up checking my alignment and the toe was off.. too much toe out. I do my own alignments so it was an easy fix.
07 Z4 M Coupe AW/IR |
08-28-2019, 05:26 PM | #10 |
Rep 12,565
My toe’s set at zero... Do you remember what your final toe settings were ?
08-29-2019, 08:59 AM | #11 |
Rep 1,373
Set at zero too... when i had the vibration i had toe out.
08-30-2019, 01:46 PM | #12 | |
Rep 97
perdidit in spatio
18" Arc-8 - Michelin Cup2 - KW V3 - GC camberplates - RE trans mounts - VT engine mounts - Vorshlag RTAB shims - RPi - stubby - CDV del |
08-30-2019, 02:56 PM | #13 |
Rep 12,565
How’d you diagnose it before replacing the tie rod? Not that I doubt your experience but I just don’t want to throw money/parts unless I can see the potential connection.
08-31-2019, 03:02 PM | #14 | |
Rep 263
Also the ball joint in a control arm would cause similar vibration (I had it on other cars, not the Z, before). I know you said the control arms are new, but still worth to check in case you could hit something on the road after you installed them. |
08-31-2019, 03:11 PM | #15 |
701
I'm going with tie-rods. It's unlikely that the new parts that have been installed would have failed that quickly, it's much more likely that the parts remaining with 50,000 miles are failing.
Here's a how to on checking. |
09-01-2019, 06:43 PM | #16 | |
Rep 12,565
Thanks, I did a similar test when I originally thought it could be the bearings and it didn't exhibit any noise or play. Last edited by 3002 tii; 09-01-2019 at 08:33 PM.. |
09-02-2019, 02:18 AM | #17 | ||
Rep 263
Just shooting in the dark - can a bad shock or shock mount cause something like this? |
09-02-2019, 08:45 AM | #18 |
Rep 12,565
I pulled on the wheel and didn’t hear any noise but I’m going to check the actual tie rod to see if there’s any play or rotation by the joint. Maybe it’s so slight that it’s only noticeable at higher speeds.
09-02-2019, 09:13 AM | #19 |
Rep 1,793
Drives: E86 3.0si
Think there's been a lot of good suggestions here and maybe an experience I had can help a little. When I watched the video and saw the steering wheel shake, I immediately thought inner tie rod play. Why?..Because it happened to me, not with a Z4M, but with a high mileage front end where I had renewed ~everything~ including tie rod ends. The steering wheel wobble started at 50 mph though. In my case, it turned out to be inner tie rod wear. Once I saw the wear of inner tie rods I replaced the rack and all was good.
Then when I saw that your toe was set a zero degrees, any play in the rack and pinion can result in a toe out condition...equaling wheel shimmy. So, my suggestion would be to go back and carefully check for movement in the tie rod ends. Think two people would be best...one to manipulate the wheel while one eyeballed the situation. One other thought comes to mind when there's talk about wheel balance. One vehicle I have is incredibly sensitive to wheel imbalance. As a result, I'm a firm fan of having wheels done on a Hunter Road Force machine. |
09-03-2019, 12:34 AM | #20 |
Rep 97
You might also check for play in the tie rods by going into a curve and see if the shimmy decreases or goes away. I.e you put pressure on the tie rods.
perdidit in spatio
10-30-2019, 07:57 AM | #22 | |
Rep 399
any updates on this Issue? I have same symptoms |
