      07-06-2018, 04:45 PM   #1
robert16
Drives: 2007 Z4 SI 36,000
Yellow warning brake and triangle
So I’m driving, fast right turn and a yellow word “brake” and the yellow triangle with the circle around it came on. Both yellow and at the same time. Wasn’t running as well on way home .
This is not a flashing light, it’s on and solid and does not go off.
What is this?
I have a code reader? Gonna look now
What caused this and does it happen often
Thanks
Rob
      07-06-2018, 05:15 PM   #2
robert16
My scanner says
Dsc steering angle sensor
5E40
I think it’s the wheel sensor or speed sensor
Could use some help
      07-06-2018, 09:37 PM   #3
robert16
My scanner cleared the codes.
      07-08-2018, 09:56 AM   #4
Punisher3.0si
Drives: 2007 E86 manual
Sounds like the steering wheel sensor is going bad
      11-12-2019, 07:32 PM   #5
BG351
BG351's Avatar
Drives: 06 325i 08 Z4
Rob, I've got the same thing on my '08 Z4; what scanner do you have? Thanks, Bill.
      11-13-2019, 02:26 PM   #6
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
There are previous posts on this phenomenon. The steering wheel sensor can be reset/calibrated, it sometimes just "loses its way". If I recall, another culprit for this code could also be a TPMS monitor sensor (the piece on the car) going bad.
      11-22-2019, 09:15 AM   #7
wdb
dances with roads
wdb's Avatar
4718
Could be steering angle sensor, wheel sensor, or the DCS/ABS pump. In my case it was the pump. I could clear the code but it would come right back again the next time DCS was triggered.
Some folks have been able to clear a steering angle code by turning the rack fully lock-to-lock a few times. My guess is that it resets and/or frees up the sensor.
      11-22-2019, 04:39 PM   #8
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
^WHS. Turning lock to lock several times is part of the reset process after clearing the code. Can't hurt to try just turning lock to lock
