08-18-2021, 05:16 PM | #23 | |
Rep 2,546
Here's one where I wiped off 1/2 the lens to show the difference. I always clean them when I do dual AE LED ring retrofits for people. Also, the wire insulation can deteriorate behind the projector which should be repaired with some liquid electrical tape. |
SD ///M42992.00 |
08-18-2021, 08:27 PM | #24 | |
Rep 4,057
SD ///M42992.00 |
08-18-2021, 09:12 PM | #25 | |
///Multiple
2992
Rep 4,243
Do you just stick a microfiber cloth through the opening to clean the inside of the lens? Any particular cleaning product or technique that you recommend? I'll take a good look at all of the wiring. With my luck, the rats/rabbits might have nibbled on those wires as well.
08-18-2021, 09:17 PM | #26 |
///Multiple
2992
Rep 4,243
I'm not anticipating any code issues because it's a direct replacement for the OEM bulb. My understanding is that LED replacements cause code issues and these are D2S Xenon bulbs. I'll make sure to come back and update this thread after I install them and take them out for a spin at night.
08-18-2021, 09:54 PM | #27 | |
Rep 2,546
But sure, if you don't want remove the projector, just leave the foggy haze on the lens and live with it Those wires in the pic are internal to the headlight so there's no way critters can get to them to nibble. Here's another pic of a 1/2 cleaned lens, imagine that haze on both sides of the lens, it has to effect the light output. |
08-19-2021, 09:13 AM | #28 | |
Rep 4,057
08-21-2021, 07:57 PM | #29 |
///Multiple
2992
Rep 4,243
pungo Huz-Z
Ok, damndest thing. I got the car up on the QJs and took off the wheels. I started on the driver side, popped off the plastic cover, turned the igniter counter-clockwise and pulled it off, released the wire clips on the bulb, took it out, replaced it, lined up the igniter and clicked it in place clockwise, put everything back together, tried the headlights, everything's fine. I repeated this on the passenger side, only the igniter was way tighter, but I managed to loosen it with a little force. Repeated everything on this side, only when I put the igniter back in place, it wouldn't turn clockwise at all, wouldn't even budge. After trying several times with no luck, I finally decided to go back to the driver side and remove that igniter. Put it in place on the passenger side and it easily turned clockwise and clicked into place. Tried the reluctant one on the driver side, and again, no luck. Put the good one back on the driver side, clicked in, no problem. Took the reluctant one back to the passenger side and tried again and managed to break off one of the plastic clips. I examined both igniters side by side and for the life of me, I can't see any difference. This one definitely violated the rule that the first time is the hardest, and after that, it's a piece of cake. Since I just can't get this to install correctly but the other one does, plus I broke off a tab, I'm just going to order a new one from Amazon. It's $58.95, way less than the $106.49 from getbmwparts.com or the $82.88 from ECS Tuning, and I'll get it later next week. (FCP Euro is $120!) EDIT: Put everything back together with the passenger igniter in place but not clicked into place clockwise, and both lights work just fine. Weird, because I didn't think the bulb contacts would line up correctly if it wasn't clicked into place. Still going to put the new one in though. pungo, I looked at removing the projector lens, but those 4mm nuts are REALLY tiny, they're really recessed with stuff in the way, and I could see this just becoming exponentially worse and turning into a complete disaster, so I passed on that. I can see some haze on the projector lens on the passenger side because it actually looks a little smudged and I assume the other side has similar haze, but I'm just going to have to live with it. I wish I'd known about this when I had the bumper off for over a year in the last couple of years because it would be way easier if the headlights were removed.
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 Last edited by SD ///M4; 08-21-2021 at 09:40 PM.. |
08-21-2021, 10:21 PM | #30 | |
Rep 2,546
I've had trouble in the past with a few lights where the tabs on the igniter didn't seem to want to seat properly. I think I remember the black inner part of the igniter can get out of alignment and needs to be rotated slightly? It's been a while, but I do remember it tripping me up more than once. I can understand you being leery about removing the projector to clean the lens. Yes, the nuts are small (7mm), you need a deepwell socket, preferably with a magnet and you wouldn't want to drop a nut in there Definitely way easier on the workbench. The lens is a fresnal type, a popular upgrade is to swap it for a ZKW-R clear lens for a better hotspot and sharper cutoff. If you really want to step up your lighting, upgrade the projectors. With your new bulbs and some Morimoto EvoX-R 2.0 projectors, they would be incredible https://www.zpost.com/forums/showpos...02&postcount=2 |
08-21-2021, 10:45 PM | #31 |
Rep 355
SD-That sucks. I just did this tonite, and it worked out fine.
The only snag I had was one of the igniters wouldn't fit because one of the bulb push clips came undone and it took me a few tries before I realized it.
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
08-22-2021, 12:52 AM | #32 | |
///Multiple
2992
Rep 4,243
I took it for a drive tonight and my overall impression is that everything is a bit brighter. On low beam, there is quite a bit of light to the driver left and directly in front of the car. There is a much more distinct cutoff that rises diagonally to the right and then flat directly in the middle of the lane ahead. On high beam, the "half dome of light" that this car emits is definitely brighter, particularly when driving down a residential street, illuminating the houses and trees on either side but also a bit further down the road. One of the reasons I looked into light improvement is that the lights on my '16 M4 are so dramatically better that driving the Roadster at night feels a little like I'm driving blind in comparison. The other reason is that the passenger beam was sometimes dropping out and a good whack would bring it back. I hit several potholes tonight and the passenger beam stayed lit, so I seemed to have solved that problem. It may very well be that the igniter is misaligned, so the new one should be a definite fix. If this was my everyday driver and got driven more at night I might consider even better lighting. It's a third car and gets drive sporadically at best, mostly in the spring and fall, and only for fun. I appreciate all of your feedback!
08-22-2021, 12:54 AM | #33 |
///Multiple
2992
Rep 4,243
Yeah, I discovered during one attempt to twist the igniter that I hadn't put the bulb clips in place at all and when I removed the igniter the bulb came out too! So glad I didn't break it!
08-22-2021, 01:11 AM | #34 |
///Multiple
2992
Rep 4,243
I installed them tonight and took a test drive. See my reply to pungo. They're probably worth the upgrade if you drive a lot at night and want a little extra light and are willing to pay the price. If you just want to replace both because one is out, I read one comparison that I may have linked to above that said that while this was the best D2S bulb overall, the DMEX bulb is better than the original and ranked pretty well at 1/3 the cost!
EDIT: I came back and removed the link to the cheaper DMEX bulb based on comments by pungo later in this thread.
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 Last edited by SD ///M4; 10-06-2021 at 04:53 PM.. |
08-23-2021, 08:20 AM | #35 | |
Rep 4,057
Thanks! |
08-31-2021, 11:26 AM | #36 | |
Rep 4,057
Is this the right bulb? https://www.amazon.ca/OSRAM-Xenarc-N...0424307&sr=8-1 I think that includes two bulbs. Is there any difference for North American left hand drive cars versus vehicles sold in the United Kingdom where folks drive on the other side? |
08-31-2021, 05:04 PM | #37 |
Rep 355
08-31-2021, 05:26 PM | #38 |
Rep 2,546
08-31-2021, 07:27 PM | #39 | |
///Multiple
2992
Rep 4,243
09-01-2021, 07:54 AM | #40 |
Rep 4,057
09-27-2021, 01:14 PM | #41 | |
Rep 4,057
Thanks for the guidance!!
Huz-Z
SD ///M42992.00 |
10-03-2021, 01:26 PM | #42 | |
Rep 12,565
FYI one of first upgrades I did on the M were the projectors. Made huge difference… https://www.zpost.com/forums/showthread.php?t=1656727 |
10-03-2021, 04:20 PM | #43 | ||
Rep 2,546
Business Name:Guangzhou Suguang Technology Co., Ltd. You saved money on the bulbs, but here's what Chinese bulbs do to the reflector. I've seen way too many ruined reflectors from Chinese bulbs, that's why I posted it earlier in the thread as a warning. Left = burned reflector from Chinese bulb, right = normal reflector. |
10-03-2021, 07:44 PM | #44 | |
Rep 4,057
“ The code on the safety label of your OSRAM packaging has been authenticated” |
