      02-28-2013, 12:46 PM   #1
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
Just got a quote on spring installation...
$828 including an alignment from an indie. Ouch! Guess I'll be getting dirty. That was for springs only and no dampers. Can only imagine what that would run on the Roady.
      02-28-2013, 01:15 PM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
thats steep!
..ive seen prices for $50/corner +alignment
      02-28-2013, 01:21 PM   #3
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
thats steep!
That much more reasonable. Have no idea what they were thinking. I can only guess something was lost in translation. He knew it was just springs and I had the parts, so don't know. It's an indie I've used before and got good value from. Who knows...
      02-28-2013, 01:36 PM   #4
Incompatible
Drives: 07 AW Z4C 3.0Si
Rears are quick and easy, fronts are more involved but a number of us have done it ourselves.
      02-28-2013, 01:41 PM   #5
Spedracer81
Drives: Z4MC
Ditto, springs are easy just did mine took 2hrs..rear are easy, front are a bit more involved..
I bought spring compressors for the front but I don't think you really need them..but for safety I did..
      02-28-2013, 01:47 PM   #6
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
Excellent. I did some pre-work studying on it and it doesn't look bad at all. I did springs on all four corners on a 2001 Prelude and outside of taking a while, it's not a big deal. Just stay focused and make sure everything is secured properly.
I plan to check out a spring compressor from Autozone.
      02-28-2013, 02:35 PM   #7
Spedracer81
Drives: Z4MC
I got mine at Pepboys for $40..sucks but its a nice tool to have..good luck
My car after 400 miles on springs:
      02-28-2013, 04:47 PM   #8
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
^ Looks perrrrfect! $40 for the alignment or per corner on springs?
      02-28-2013, 10:30 PM   #9
Spedracer81
Drives: Z4MC
oops..I ment $40 for the spring compressor tool....I did this myself..
When I did some research on prices I got estimates of $350-400
The rear sits nice, I would like to get another 1/2" drop outa the front..but I live in Jersey and the roads are rough..it is what it is..
      02-28-2013, 10:38 PM   #10
Spedracer81
Drives: Z4MC
Heres a beter shot..
      03-01-2013, 07:26 AM   #11
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
$350-400 seems pretty reasonable if you don't have the tools or time, but still a motivator to DIY. Yours sits great. I am going to do some before and after shots before I change the springs.
      03-01-2013, 11:01 AM   #12
Incompatible
Something to keep in mind as one of your first steps is to disconnect the headlight leveler linkage which IIRC is found on the passenger side (US cars) front and rear A arms. If you drop the arms with the linkage attached, they may be damaged. Good luck.
      03-01-2013, 12:19 PM   #13
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
Thanks for the heads up. I will do that.
